Re: How fast have you been with a standard stroke 383? [Re: hudsonhornet7x] #2997006
12/20/21 11:57 AM
12/20/21 11:57 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Me, personally... 14.0 at 101 MPH in a '69 Super Bee 383 4-speed... back in either '79 or '80. Hey, you asked!
Likely my favorite 383 car ever: Dave Boertman's '71 Challenger SS car. It was a mid-to-high 10-sec car with an "interesting" backstory as described HERE.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: How fast have you been with a standard stroke 383? [Re: Brad_Haak] #2997045
12/20/21 02:06 PM
12/20/21 02:06 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
What oil pumps were being used for these 7,500+ rpm combos? How loose on the bearings? Presuming these faster times were roller cam/tunnel ram/open header combos with 5K+ 8" converters and 5.xx gears...
Almost forgot that just recently I finished helping my friend build a 383 stroker (438"). It's a pretty mild street cruiser combo. OOTB 440 Source heads, about 9.3:1 C.R., 228/232 @ .050" hydraulic FT cam, RPM intake, headers, 750 carb. Made just under 450 hp and 450+ lb. ft. of torque. It did rev to 6,000 rpm though which is more than I can say for the heap in my own car. Combo is going in a '66 Fury with highway gears and regular tires. Won't be raced but maybe it might go in the 13's on slicks.
383/438 On the dyno For B Bodies Only
'71 Duster
'72 Challenger
'17 Ram 1500
Re: How fast have you been with a standard stroke 383? [Re: Brad_Haak] #2997050
12/20/21 02:09 PM
12/20/21 02:09 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wow, lots of trickery going on there!
'63 Dodge 330
11.19 @ 121 mph
Re: How fast have you been with a standard stroke 383? [Re: Gtxxjon] #2997086
12/20/21 04:43 PM
12/20/21 04:43 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Originally Posted by Gtxxjon
There was a fantastic 383ci engine article in an old Mopar book, ''Musclecar and Hi-Po engines''
Chrysler themselves got Victor Edelbrock to do a 'Hotrod' article on a NEW factory 383ci engine in 1967!
They had been hearing of ‘bad press’ for the 335hp ‘383ci’ so 'MOTHER MOPAR' wanted to put the record straight lol.
On the Dyno, a brand new low mileage 383ci made only 280 horses... fan
So with lots of machine work and the right camshaft, they got it up to 420 horses. drumhit
The article does not say which heads were used 516 or 915 (440) heads?
The biggest problem being was 'factory over-tight' clearances.
''Freeing the horsepower'' was just more piston to wall and bearing gaps, worth 100hp... drinking
My car, Duster @ 3000 pounds and me at 180 ran 118, the Wallace calc says 400 Hp. 030 over pop up TRW slugs, stock bottom end, .509 cam, 915 stock heads (triple springs), isky rockers, Torker intake, 3310 Holly, Hooker headers, 4.88 gears 11.5X 29.5 M&H slicks and street Hemi converter. A little port work in the heads and I’m sure it would have run faster
Re: How fast have you been with a standard stroke 383? [Re: LaRoy Engines] #2997115
12/20/21 07:06 PM
12/20/21 07:06 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
Back in the day We ran low 7's {7.10} in a 69 RR. stock stroke and stock bore 383. It had an old Cam Dynamics Flat tappet cam. Adv 310/585. I don't remember the duration at .050. 906 heads
Re: How fast have you been with a standard stroke 383? [Re: Cab_Burge] #2997488
12/22/21 01:05 AM
12/22/21 01:05 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Originally Posted by Cab_Burge
I think I remember Dave Wren running in the 9.80s back a long time ago with his 1971 Cuda 383 SS/I car in the mid 1970s boogie
If I'm remembering correctly he let the clutch out at 8800 RPM and shifted it around 8200 RPM shock shruggyThat motor was a unbored 400 block given to him by the Mopar factory drag engineers that they had built and flogged a bunch on the dyno before giving it to him to race to outrun the 350 Chevy in that class: devil:
You mean 10.80s? The record minimum today is 10.05...
Re: How fast have you been with a standard stroke 383? [Re: cudadoug] #2997498
12/22/21 03:13 AM
12/22/21 03:13 AM
NHRA will reset the SS and Stock records to a minimum after they had been the record for two years, at least they use to do that. scope
I'm pretty sure about the numbers Dave Wren ran with that car Mopar gave him that motor for, Bob Mazzolini ran almost that quick with his 1971 SS/IA 383 Cuda a bunch of years later in another Mopar prep body in white car from Portland, it was trick also whistling CRS on remembering the original owners of that car, they had several Dodge and Plymouth dealerships in the Portland area back in the late1960 and early 1970, Italian last name: work shruggy
Re: How fast have you been with a standard stroke 383? [Re: Cab_Burge] #2997503
12/22/21 06:54 AM
12/22/21 06:54 AM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
Quickest Mike Cotton ran this year was 9.73 in SS/IA trim (at least per Nitro Joe’s stats) with his Cuda. Jerry Hatch is also capable of running around that range in the ex-Eric Bell beautiful orange Challenger. Speaking of Wren, I was running brackets at Mission BC in 2005 and Dave rolled out of his moss covered trailer a primered 63 with a max wedge “he had thrown together”. Best sounding motor I’ve ever heard. The master still had his touch, might still but haven’t heard anything about him in the last 5 years.
Re: How fast have you been with a standard stroke 383? [Re: RMCHRGR] #2997706
12/22/21 10:39 PM
12/22/21 10:39 PM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
Stock volume pumps. 0035" mains. 0028" rods no problems.
Hutch
Re: How fast have you been with a standard stroke 383? [Re: cudadoug] #2997734
12/22/21 11:54 PM
12/22/21 11:54 PM
A727Tflite Offline
A727Tflite  Offline
SS/AA cars were barely in the 9’s - no way did Wren or anyone else run that fast in IA.
Re: How fast have you been with a standard stroke 383? [Re: A727Tflite] #2997764
12/23/21 02:43 AM
12/23/21 02:43 AM
That car ran in SS/I, not SS/IA.
Dave Boertman SS/JA 1971 Challenger was a lot slower than Wrens 1971 Cuda was shruggy
Dave was thrown out of the Indy Nationals two years later running that quick and fast after winning the class in teardown in either 1974 or 1975 , the wheelbase was 1/8 inch to short rant
He was one of many sportsman racers sponsored by Mopar in the NHRA sportsman classes before they went BK in 1980 due to the unfair weight advantage NHRA had given to the Chevy Pro Sttock racers racing against the Hemi cars in 1973. down
I remember the SS/A and SS/AA cars running in the mid to low nines in the 1974 Winternataionals. shruggy
Re: How fast have you been with a standard stroke 383? [Re: Cab_Burge] #2997772
12/23/21 05:54 AM
12/23/21 05:54 AM
A727Tflite Offline
A727Tflite  Offline
Much as I hate to say it the Chevies had us covered.
Notice the date the records were set.
Re: How fast have you been with a standard stroke 383? [Re: A727Tflite] #2997883
12/23/21 02:12 PM
12/23/21 02:12 PM
blush realcrazy shruggy
Re: How fast have you been with a standard stroke 383? [Re: A727Tflite] #2997908
12/23/21 03:23 PM
12/23/21 03:23 PM
fredericksburg,va
fredericksburg,va
Just like today, nobody runs as fast as they can or weight is added to your class. The big hitters never ran all out. Chrysler told the A cars to not bomb the record so the little guys in their class have a chance, more cars more publicity.
Re: How fast have you been with a standard stroke 383? [Re: tjmarcus1] #2997921
12/23/21 04:09 PM
12/23/21 04:09 PM
gregsdart Offline
gregsdart  Offline
Year, 1970. US hywy 2 west of Grand Forks ND. Observed 5750 on my tach, converted to 138mph. 1968Coronet, 4spd. Stock motor, 3.23 gears. Handled loose as a goose!
Re: How fast have you been with a standard stroke 383? [Re: cudaman1969] #2997976
12/23/21 06:32 PM
12/23/21 06:32 PM
A727Tflite Offline
A727Tflite  Offline
Most fast cars sandbagged to a point but I don’t recall ever seeing/hearing any Chrysler product run a second under the record.
I know of a few Chrysler products that won class by running out the backdoor and ended up bombing the record, but no where did they run more than a tenth or two under.
Was directly involved in all the Chrysler “activities” from around 67 to 80. Pretty much knew what cars were sandbagging and which ones were bogus.
Some “heroes” won SS back in the day that should have been tossed but even they didn’t run a second under the record either.
And the other thing to use as a benchmark. A similar car in a differentiations Eliminator like MP.
1975 - A/MP 68 Dart at 426 @ 3400 lbs. Tunnel ram, ported aluminum heads, ran 9.45 @ 145-148 mph.
How would a SS legal SS/A car go that fast the same year with “legal” heads and a crossram.?
Re: How fast have you been with a standard stroke 383? [Re: A727Tflite] #2998176
12/24/21 12:01 PM
12/24/21 12:01 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i went 10.50 at 130 with my old challenger in street trim with a 6-71 stock eddy heads. 15lbs boost.
Re: How fast have you been with a standard stroke 383? [Re: A727Tflite] #2998239
12/24/21 05:03 PM
12/24/21 05:03 PM
fredericksburg,va
fredericksburg,va
Those years all run together now but pro stock was barely in the nines around 70-72, iirr. Super Stock race at the beach in 69 or 70 the A cars were running 10.60s-80s and the best 65 A990 Plym 4 speed went 11.07. Sam P. had a 69 GTX Hemi 4 speed convertible running 11.50s. We thought they were flying. No door slammer got close to the nines
Re: How fast have you been with a standard stroke 383? [Re: cudaman1969] #2999743
12/29/21 10:47 PM
12/29/21 10:47 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
I saw Doug Duell at Beech Bend this year working out a 383 they had in the Hemi Cuda. I think it was running GT/GA which I believe is a 10.40 index so I’m pretty sure its in the 9’s.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
