Mufflers #2997514
12/22/21 09:12 AM
12/22/21 09:12 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Who's muffler are you guys using that helps tone down your race car but doesn't hurt the overall performance much? I currently just have 6" Schoenfeld Race Muffler on my car, but looking to quiet the car down some. Would like something that milds the sound down, but doesn't sound like a mustang going down the track either.
Re: Mufflers [Re: DusterKid] #2997522
12/22/21 10:07 AM
12/22/21 10:07 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Pretty much any straight thru muffler will be zero loss,unless it necks down the exhaust size. If you have 3" collectors and exhaust a 3" straight thru muffler will be zero loss.
Bigger mufflerbodyvolume will make the car quieter.
Mufflers further away from the collectors will help tame down the sound alitle aswell.
X or H pipes cuts down the tone alitle aswel.
Magnaflow
Dynomax Ultra flow
Borla
Are usualy pretty good.
Hooker has a few good mufflers aswell.
Re: Mufflers [Re: DusterKid] #2997543
12/22/21 11:08 AM
12/22/21 11:08 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Kooks make really nice polished stainless mufflers that knock down noise, nice sound, no effect on my car at the track.
Pretty, and not expensive.
https://www.summitracing.com/parts/...G6tf39AIVahPUAR2RrQ-mEAQYAyABEgJKufD_BwE
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Mufflers [Re: B3422W5] #2997765
12/23/21 02:44 AM
12/23/21 02:44 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
These cut my noise down a little (with emphasis on “little”). Flowmaster FlowF/X 3” bullets.
Re: Mufflers [Re: StealthWedge67] #2997799
12/23/21 09:24 AM
12/23/21 09:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run 3” Ultra-flows on the street car. Noise level isn’t to bad. They are straight thru and stainless.
Doug
Re: Mufflers [Re: dvw] #2997834
12/23/21 11:37 AM
12/23/21 11:37 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Dynomax bullet on my Challenger. They help quiet it down some. I mean a little, very little.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Mufflers [Re: 6PKRTSE] #2997838
12/23/21 11:51 AM
12/23/21 11:51 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I like Pypes Race Pro. Quietest straight through muffler I've found. This is dual 3" with h-pipe and tailpipes.
https://www.youtube.com/watch?v=422uTiz78bs
Re: Mufflers [Re: INTMD8] #2997865
12/23/21 01:29 PM
12/23/21 01:29 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
SpinTech mufflers.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Mufflers [Re: DusterKid] #2997881
12/23/21 02:11 PM
12/23/21 02:11 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
https://extrememufflers.com/ I use these mufflers in the square oval or what ever they call it. They sound on the deep side, but a bit loud. They are very light.
Re: Mufflers [Re: mopar dave] #2997902
12/23/21 03:05 PM
12/23/21 03:05 PM
Renton Washington
Triple Threat Offline
Renton Washington
Borla XR1's
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Mufflers [Re: Triple Threat] #2997998
12/23/21 08:18 PM
12/23/21 08:18 PM
BigFish69 Offline
BigFish69  Offline
Do you know the weight on those kooks mufflers, was there any performance loss ?
Re: Mufflers [Re: BigFish69] #2998006
12/23/21 08:41 PM
12/23/21 08:41 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
No known performance loss. Not sure what they weigh. I have the 3 inch ones like i linked to. Guessing 4 or 5 pounds each. They are polished stainless.
Edit….4.33 pounds
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Mufflers [Re: DusterKid] #2998223
12/24/21 02:51 PM
12/24/21 02:51 PM
I used a set of the older crimp style Magnaflow 14 inch long by 7 inch wide ovals with 3.0 inch side inlet with a perforated pipe exiting in the center. The muffs were mounted at the rear bumper and fed by 3.0 inch pipes off the 3.5 inch Hooker fenderwell A body headers, that car slowed down .03 ET in the 1/8 mile with them on and .2 MPH, 7.01 ET hooked up at 95.3 MPH, 6.98 ET at 95.5 MPH with the complete system removed shruggy
IHTHs work
That car was a real hoot, not real loud at part throttle cruising but a lot louder at WOT devil
Best run with the exhaust system on in the1 /4 mile on Oregon pump swill was 9,994 ET at 134.6 MPH weighing 3450 Lbs. with me in it boogie
Re: Mufflers [Re: Cab_Burge] #2998227
12/24/21 03:30 PM
12/24/21 03:30 PM
gregsdart Online content
gregsdart  Online Content
At the end of your collecter, what ever length works best, go up an inch in diameter with an adapter , and add a straight through muffler of the larger size. Add an extension on to the muffler. As long as the system stays at least an inch bigger than the collector you have a zero loss system, except for the extra weight.
Re: Mufflers [Re: gregsdart] #2998600
12/26/21 01:11 PM
12/26/21 01:11 PM
moparx Offline
moparx  Offline
if using a complete exhaust system, [x pipe with tail pipes] would race bullets at the end of the tail pipes [where the gasses are the coolest] be the least restrictive place in the system to place them ?
beer
Re: Mufflers [Re: moparx] #2998611
12/26/21 01:41 PM
12/26/21 01:41 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
[s][/s]
beer
Performance matters less the further back you go on the exhaust system
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Mufflers [Re: B3422W5] #2998683
12/26/21 07:36 PM
12/26/21 07:36 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Years ago my street car ran 11.72. It had 3” to the back bumper with Flowmasters. Removed the entire system (70lbs). Made a back to back run. It went 11.66
Doug
Re: Mufflers [Re: dvw] #2998852
12/27/21 01:34 PM
12/27/21 01:34 PM
moparx Offline
moparx  Offline
were the flowmasters in the normal position around the rear seat, or at the end of the tail pipes ?
some have suggested mounting the mufflers at the rear bumper.
i was wondering why ? better noise control ? less restriction because of the cooler exhaust gasses ? another reason ?
beer
Re: Mufflers [Re: moparx] #2998870
12/27/21 02:23 PM
12/27/21 02:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Engine Masters on MTOD did an episode on this.
The Dynomax UltraFlows performed really well and is what we have on the car.
3" pipe to the mufflers and 45* turn downs at the rear axle. Car is quiet enough to have a conversation in going down the road but has minimal restriction.
I have had issues with one that keeps cracking where they stamped "DYNOMAX" in it. We've had to weld that up a few times but it's just on the one muffler. Other than that minor issue, very pleased with them.
'63 Dodge 330
11.19 @ 121 mph
Re: Mufflers [Re: GY3] #2998902
12/27/21 03:34 PM
12/27/21 03:34 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I remember Spiro Pappas' Camaro in old NMCA Super Street had Borla XR1 collector mufflers with 4" pipe to the rear axle. Was the quietest, best sounding exhaust I ever heard.
