aluminum wedge block ( RB) #2996185
12/17/21 04:42 PM
12/17/21 04:42 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Hi folks, Been a while since i posted here, had to have emergency lung surgery from a drs mistake , 13 days in icu and 4 weeks of being chained up at home, and i don't even like television!
But, im back at work now and, back here needing help.
We ordered a Bill Mitchell aluminum block 6 months ago, my buddy ordered it from Bill instead of Todd Marsh or Best and, well, you guys know the rest of the story and, NO, i'm not busting Bill's chops, i understand what he has to do and, the dealers simply must come first.
However, we are running out of time, heads are at Dwayne's , new rockers ordered etc and, we are still in the loop of "blems ate up too many blocks, maybe next month. I get it, again, this post is saying Nothing negative about Bill Mitchell , its just business.
So, does anyone on here have a aluminum RB block they want to sell? Trying to build a 540, know anyone that wants to sell one?
If so, please hit me up.
Thanks so much as usual.
Praying everyone has a wonderful Christmas.
P.S. if Santa brings you one too many engine blocks, please let me know! grin
Re: aluminum wedge block ( RB) [Re: RustyM] #2996264
12/17/21 09:25 PM
12/17/21 09:25 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't mean to speak for Todd, but it is my understanding that he didn't get as many BMP blocks as he expected during the last delivery.
My new B1 motor has a BMP block from Todd (I got it in April), and I put my name on Todd's list for another block during the summer (I was thinking get them while I can), and that block has not arrived yet.
The next block is to put my existing recip assembly into (from my Daytona). Currently an old Chrysler factory block from the 1970's
Good luck. All parts are harder than ever to get.
Re: aluminum wedge block ( RB) [Re: RustyM] #2996311
12/18/21 01:14 AM
12/18/21 01:14 AM
Louisiana
BiomedTechGuy Offline
Louisiana
I bought my BMP RB 4.49 bore block through my builder/dealer, and because of my situation with tight finances, and thanks to our prior business experience and his consideration, I just got mine paid for, so as much as I'd like to help, I'm not really the only one who worked towards making it happen.
I did have a question regarding the displacement you chose, as mine will be a 541 (4.25 stroke x 4.50 bore) AndyF concurred, and I guess that should be all I need to know, but I was looking at piston speed and a modest HP (6XX) and torque (700) goals, and figured that even though it will take a 4.50 stroke without clearancing, I'd be better off at 541. I'm feeding it with a 6bbl too, so there's that.
Why are you going with the 541 displacement?
Re: aluminum wedge block ( RB) [Re: BiomedTechGuy] #2996377
12/18/21 11:17 AM
12/18/21 11:17 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Don't shoot me for mentioning this, but you can build a 543 out of a 440 and maybe make do for a while. With a girdle they hold up nicely if you keep the rpm in check.
Re: aluminum wedge block ( RB) [Re: Dragula] #2996431
12/18/21 01:15 PM
12/18/21 01:15 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Keep repeating that if it makes you feel better, but that girdle plate does not hurt anything, nor does it help anything.
Feel free to post a FEA simulations to make me see the advantage they provide.
Re: aluminum wedge block ( RB) [Re: GTS340] #2996442
12/18/21 01:36 PM
12/18/21 01:36 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Keep repeating that if it makes you feel better, but that 1/4" thick girdle plate does not hurt anything, nor does it help anything.
Can you post FEA simulations that show they don't help?
I'm not sold on girdles either way, but you can't call out someone like that if you can't back up your side of the argument.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: aluminum wedge block ( RB) [Re: 440Jim] #2996506
12/18/21 04:18 PM
12/18/21 04:18 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Your correct Jim. Sometimes its simply a matter of how many clear the machining process, thats where any blems show up and he won't allow those out so, that cuts into how many blocks he gets.
Re: aluminum wedge block ( RB) [Re: BiomedTechGuy] #2996508
12/18/21 04:23 PM
12/18/21 04:23 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
We have the same stroke your looking to build, have run it for years with no issues. We just need a bit more power so, bit more bore size, new cam, Dwayne doing some head work and we should get what we need. You wont have any piston speed issues to worry about , we have turned this one 7200 many times with no issues.
Bearings we just took out after 3 years still look new and crank journals look like mirrors , rod bearings all looked good as well. I wouldn't worry about piston speed on your build.
Re: aluminum wedge block ( RB) [Re: Dragula] #2996510
12/18/21 04:27 PM
12/18/21 04:27 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
We may have no choice Dragula, really hate to do the Callies block, though it would meed our needs. I just did all the calculations/planning based on the weight loss on the nose with the BMP block.
So, may have to change plans. Don't know how long a stock block will last at 775 to 800 hp, we were at 720 with this block, yes, we use girdles.
Re: aluminum wedge block ( RB) [Re: RustyM] #2996515
12/18/21 04:33 PM
12/18/21 04:33 PM
Louisiana
Louisiana
Not to hijack, so I'll be brief. I'm assuming the quoted is referring to the 541 bore/stroke 4.50/4.25 combo. If so, that's a great report. I was curious why the OP was choosing that displacement.
As far as a factory block w/a girdle, I believe the BCR cap and girdle system is the best design, and was going to use that, BUT I figured why push towards the limit of a factory block, especially since I'm probably only going to get ONE shot at building a stroker. With the BMP block and my modest power expectations, I don't think I will ever worry about the block, or anything else breaking from being too close to its performance limits, and that peace of mind is invaluable at this point.
Re: aluminum wedge block ( RB) [Re: BiomedTechGuy] #2996821
12/19/21 08:49 PM
12/19/21 08:49 PM
Using a bigger bore than stroke to make a certain C.I. is way better plan to make more power than using a smaller bore with longer stroke to make the same C.I. in a drag race motor twocents
Look at Pro Stock and check out what bore and stroke they have used for years on an unlimited racing budget to go as fast as they can work up
Re: aluminum wedge block ( RB) [Re: Cab_Burge] #2996897
12/20/21 12:20 AM
12/20/21 12:20 AM
BigFish69 Offline
BigFish69  Offline
brand new one on face book for sale $ 5,900
Re: aluminum wedge block ( RB) [Re: GTS340] #2996926
12/20/21 07:10 AM
12/20/21 07:10 AM
Dragula Offline
Dragula  Offline
Why would I post FEA simulations? We have this same setup still running and racing in the same cars since 2010? Thousands of passes on them. And even if I did have data like that, people like you still would not believe it anyways.And you can't prove it does anything but add weight, so to each there own, but I have seen a lot of +.030 440's blow up at the drags that didn't have a big arm in them and no girdle. SO in my mind, we have the data, even if its not in the form you require.,
Re: aluminum wedge block ( RB) [Re: BigFish69] #2997042
12/20/21 01:58 PM
12/20/21 01:58 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Just bought it Fish, thanks so much.
Re: aluminum wedge block ( RB) [Re: RustyM] #2997044
12/20/21 02:05 PM
12/20/21 02:05 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Update : We have a new BMP block!! A very nice guy on facebook , who ordered one in fall of 2020 and got it this year put it up for sale as he picked up a built 605 with world block and is happy with his set up.
So, Christmas complete on the block. Now its getting bearings, pistons/rings, machine work and built.
Thanks to everyone.
Question: i see differing comments on compression loss with aluminum blocks : Is that a real issue at 775-800 hp range or just for more intensive combos. Yes we will hone with plate/correctly etc .
Secondly, using race fuels ( C12) anyone know what temp range is best target ?
Thanks in advance.
Re: aluminum wedge block ( RB) [Re: RustyM] #2997471
12/21/21 11:16 PM
12/21/21 11:16 PM
BigFish69 Offline
BigFish69  Offline
Re: aluminum wedge block ( RB) [Re: BigFish69] #2997517
12/22/21 09:17 AM
12/22/21 09:17 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
I see Bill posted yesterday on Facebook that he just received a bunch of wedge blocks into stock
Re: aluminum wedge block ( RB) [Re: JACK1440] #2997552
12/22/21 11:49 AM
12/22/21 11:49 AM
gregsdart Offline
gregsdart  Offline
Weighing in on the girdle thing with my experience.
In 2003 I dynoed a megablock 4.15 stroke 4.50 bore 528 cube motor. Made 847 hp injected on methanol . I noticed cap walk on a crossbolted megablock, Max rpm was 7400. Bob weight 2432. I put a girdle on it. Didn't take away the cap walk issue. During this time we found a minor cracking the crank by #6.
I bought a rather expensive center weighted crank from Crower and took the girdle off. The C. W. Crank eliminated about 90 percent of the cap walk. I finally needed a little cleanup and align hone in 2019.
So IMHO the girdle basically can force a large portion of any movement into a vertical motion, which may help a little. BUT THERE IS NO TRIANGULATION to stop that vertical stress completely. So end result? IMHO they may be of some benefit, but not enough for a lot of stressfully builds.
Properly done, an add on girdle would be 3 inch or more tall, or thick, if that is how you would view it. That would require a rather short oil pan, like a dragster 10 qt . The big deal about it being so tall is it would now be so rigid it could transfer stress to the pan rails in all directions, not just lateral.
