Re: Best vac pump inlet location?
[Re: dakotahotrodder]
#2996222
12/17/21 07:22 PM
12/17/21 07:22 PM
Posts: 34,880 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I tried several things till I found the right spot ..
Middle of V/C ..intake side , I no longer have pics but, did a little fancy gizmo to make it look neat ..
Not what works for one will work for another, your lost without a gauge, took lots of trial and error
On dyno worked great if front of v/c .. at track it did not
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
#2996281
12/17/21 09:55 PM
12/17/21 09:55 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
I put mine at the front of the passenger side valve cover as far forward and on top of the cover with the bypass valve beside it per the instructions from the manufacturer. I did make and have a flat aluminum baffle welded under them, but the welds broke, and the motor didn't seem to suck any more oil into the vent tank after removing the baffle and racing it without the baffle
#2996376
12/18/21 11:14 AM
12/18/21 11:14 AM
Posts: 4,206 New York
polyspheric
New York
Vacuum at the valve cover interferes with oil drain from the head. Ideally, it should be in the air space above the oil in the pan.
Boffin Emeritus
[Re: Moparite]
#2996437
12/18/21 01:23 PM
12/18/21 01:23 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
In my opinion not near as effective. What will those pull a couple of inches of vacuum as opposed as much as you want with a good pump setup. Also for what its worth I pull from the top front of the driver's side valve cover, no baffle and little oil in the tank.
#2996439
12/18/21 01:27 PM
12/18/21 01:27 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
IMO it depends on the heads being used. We have them in the front of the cover, top of the cover, intake side of the cover, depending on cylinder head being used. Our current engines have two in the front of the cover with no baffle and one in the top oft he cover. None of them pull any oil really usually just some condensation and maybe a drop or two of oil. But we don't have any external leaks either.
#2996496
12/18/21 03:54 PM
12/18/21 03:54 PM
Al_Alguire
Las Vegas
With a =1 head and Indy oiling, which I assume you have it will make little difference where it is. We have run that combo a few different times with just a fitting in the cover with no issues at all. This was a -1 headed 446 with the fitting in the top of the cover at 11" of vacuum never any oil in the tank.
#2997099
12/20/21 05:30 PM
12/20/21 05:30 PM
Posts: 154 Canada
cuda499
Canada
Where have you guys put your inlet for your vacuum pumps? I got an Aerospace pump for my big block and they recommend the front of the valve cover with no baffle, but I was thinking of installing it mid valve cover on the intake side. Any suggestions and pic's of your set ups would be great, thanks! Switched mine from valve cover to lifter valley, and it filled the catch can every time I stood on it lol. Switched it back to valve cover.
[Re: Ian]
#2997585
12/22/21 01:28 PM
12/22/21 01:28 PM
Al_Alguire
Las Vegas
FWIW I have NEVER seen the valley plate to be a good location. Alot of oil flying around in there at RPM and if you are pulling any real amount of vacuum its gonna make a mess in short order.
[Re: Al_Alguire]
#3003000
01/07/22 08:16 PM
01/07/22 08:16 PM
Posts: 10,021 MN
JERICOGTX
MN
FWIW I have NEVER seen the valley plate to be a good location. Alot of oil flying around in there at RPM and if you are pulling any real amount of vacuum its gonna make a mess in short order. Can the valley plate area be used for the relief?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3003042
01/07/22 10:10 PM
01/07/22 10:10 PM
Cab_Burge
FWIW I have NEVER seen the valley plate to be a good location. Alot of oil flying around in there at RPM and if you are pulling any real amount of vacuum its gonna make a mess in short order. Can the valley plate area be used for the relief? Why not?
[Re: JERICOGTX]
#3003198
01/08/22 03:22 PM
01/08/22 03:22 PM
Al_Alguire
Las Vegas
IMO no reson to regulate it unless you are the paranoid type. Especially with a 3 vane pump, in that case there is ZERO reason to run a regulator
[Re: Cab_Burge]
#3003200
01/08/22 03:26 PM
01/08/22 03:26 PM
Posts: 19,366 north of coder
moparx
FWIW I have NEVER seen the valley plate to be a good location. Alot of oil flying around in there at RPM and if you are pulling any real amount of vacuum its gonna make a mess in short order. Can the valley plate area be used for the relief? Why not? that kind of example would be the breather/oil fill tube on chevy engines over many years. i have even seen PVC valves plumbed into oil fill tubes [with no breather] on certain POBC engines over the years.
