Flywheel and clutch balancing #2995784
12/16/21 12:10 PM
12/16/21 12:10 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Been reading about this on all different car sites.
It seems some manufacturer's flywheel / clutch assemblies, intended for internal balance crank assembly, do NOT have good neutral balance.
McCleod, Spec, others.
If seems to be agreed that balancing your flywheel and clutch separately from the crank is a good idea. Even separately from each other, flywheel, then clutch.
Not every machine shop is equipped, or is willing, to do this.
Anyone know of particular shops that will do flywheel / clutch dynamic balancing ?
Re: Flywheel and clutch balancing [Re: hemienvy] #2995845
12/16/21 03:44 PM
12/16/21 03:44 PM
Washington
madscientist Offline
Washington
It’s a balanced assembly. That means you get the flywheel, disc and pressure plate to zero and then it goes onto crank to finish.
Re: Flywheel and clutch balancing [Re: hemienvy] #2995854
12/16/21 04:37 PM
12/16/21 04:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I just bolt the plate to the flywheel and chuck it up on our digital wheel balancer and go from there. It gets it down to 0-3 grams which is pretty good to me shruggy I've seen guys just bolt them on and trust the clutch and flywheel vendors word eek
Gus beer
64 Plymouth Savoy
Dana 60
Re: Flywheel and clutch balancing [Re: fourgearsavoy] #2995860
12/16/21 04:59 PM
12/16/21 04:59 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
If you've bought a balanced bottom end then you're pretty much stuck with having to balance the flywheel and clutch separately.
To me, balancing these separately makes absolute sense as you wouldn't want to disassemble a motor for balancing if you ever had to or wanted to change the flywheel and or pressure plate or even switch to an automatic.
As to part two of the OP's question, I know a guy BUT he's in Ontario, Canada !!!
Re: Flywheel and clutch balancing [Re: fourgearsavoy] #2995863
12/16/21 05:11 PM
12/16/21 05:11 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
Couldn't be happier with the before/after 8600rpm results from my DIY flywheel/clutch static balancing fixture...
DIY Static Balancing Fixture Webpage
Grant
Re: Flywheel and clutch balancing [Re: hemienvy] #2995944
12/16/21 09:37 PM
12/16/21 09:37 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The flywheel is bolted to the crank flange, the pressure plate bolted to the flywheel, so it makes sense to balance them as an assembly (assuming the PP is indexed, asymmetrical bolt pattern etc.).
However, the disc lands on the other 2 surfaces differently every time the clutch is re-engaged.
How can this work?
The disc's friction part of the radial mass is so evenly distributed that a tiny balance error is harmless. If its perimeter were 3" thick or 30" OD it would have to be neutral balanced separately.
How do simple rotational and dynamic balance differ?
If the pieces were all completely symmetrical in 3 dimensions this would work, but the largest piece (PP) is probably eccentric as to weight distribution in its thickness (front to back distance) even if radially correct.
This means the center of mass is not exactly parallel to the rotational center, but mis-aligned. The PP tries to rotate on its mass axis, and introduces a new vector. Dynamic balance senses this and IDs the correction.
Boffin Emeritus
Re: Flywheel and clutch balancing [Re: weedburner] #2995955
12/16/21 10:20 PM
12/16/21 10:20 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Grant
There is so much good stuff on that page. I am going to tighten up the face plated 3-4 slider on my a833 this winter. Thanks Grant!
Re: Flywheel and clutch balancing [Re: weedburner] #2995972
12/16/21 11:25 PM
12/16/21 11:25 PM
A727Tflite Offline
A727Tflite  Offline
Grant
Great info and impressive approach.
Your door closer provided me with a solution on an issue I was currently working on.
