Re: ATI super damper with BBC hub
[Re: AndyF]
#2994838
12/13/21 07:00 AM
12/13/21 07:00 AM
Posts: 642 South Dakota
dakotahotrodder
South Dakota
Thanks Andy! I was wondering if that was the route I was headed. Thanks Jim for the picture showing what is done. I will get this done.
[Re: AndyF]
#2994906
12/13/21 01:35 PM
12/13/21 01:35 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Same here. My old ATI damper has the Mopar 6 bolt pattern. Wasn't much available for Mopar back then. I made most of my FEAD out of many left over pieces from other Ford and Chevrolet builds laying around and came up with this.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2994910
12/13/21 01:40 PM
12/13/21 01:40 PM
Posts: 11,536 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yep, the "old days". ATI damper with Chevy accessory bolt pattern. Not much made crank trigger and pulley wise for Mopar then. Easier to make brackets for the pickup etc, than to reinvent the wheel.
No reason not to do something to use the most common accessories available now either.
[Re: 440Jim]
#2994952
12/13/21 03:45 PM
12/13/21 03:45 PM
Posts: 31,000 Oregon
AndyF
Andy, I like that big nut on the end. Should be suitable for turning the engine with a wrench by hand. Yes, the spline drive setup from Peterson is strong enough that the engine can be rotated with the large nut. The Chevy style mandrels will break if you try to use the center bolt to rotate the engine.
[Re: AndyF]
#2994970
12/13/21 04:37 PM
12/13/21 04:37 PM
Posts: 16,923 NC
440Jim
NC
Andy, I like that big nut on the end. Should be suitable for turning the engine with a wrench by hand. Yes, the spline drive setup from Peterson is strong enough that the engine can be rotated with the large nut. The Chevy style mandrels will break if you try to use the center bolt to rotate the engine. Yea, it is my understanding that the center bolt on those is just to clamp the pullies/spacers together; not to turn the engine to TDC etc. Especially with spark plugs installed ! Do you think the other aluminum mandrels would be OK to turn the engine by hand if one of the spacers was replaced with a big wrench hex with a keyway to the mandrel center? (or like some pulleys have a set screw with sized end to engage the keyway). For example a 1" dia mandrel with a 1-1/2" hex; or a 1.5" dia mandrel with a 2" hex.
[Re: AndyF]
#2995339
12/14/21 06:45 PM
12/14/21 06:45 PM
Posts: 6,136 Melbourne , Australia
LA360
I made a custom drive for a friends engine. I machined a square drive in to the front, so he could turn the engine over easily. Not sure if I have a pic for it, if I find one I will post it.
Alan Jones
