Throw-out Bearing Recommendation - 23-Spline #2994563
12/12/21 11:02 AM
12/12/21 11:02 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Any recommendations for a high quality throw-out/clutch release bearing for a 23-spline? Looking for one made in USA/Canada.
Re: Throw-out Bearing Recommendation - 23-Spline [Re: floyd] #2994570
12/12/21 11:22 AM
12/12/21 11:22 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
When I put in my Center Force like 20 years ago the bearing that came with it went bad quick.Got lucky and my buddy at AZ had an old Timken that had sat for years.Been in since like 03 and no problems.IIRC Summit still carrys some decent ones Rocky
Chrysler Firepower
Re: Throw-out Bearing Recommendation - 23-Spline [Re: floyd] #2994580
12/12/21 11:40 AM
12/12/21 11:40 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've had bad luck with the TO bearings in the last few years. All made in China, which can be generally hit and miss, but they all use the cheapest grease known to man in them, which I think is the problem with the ones I had trouble with. Several lasted only a few thousand miles, and were verifiabilly, fully retracted when not being used. Try Brewer's.
I ended up going with a hydraulic unit from American Powertrain, which is amazing.
If you are able to swap out the old bearing with one from National or King Bearing, you would be money ahead.
Re: Throw-out Bearing Recommendation - 23-Spline [Re: jbc426] #2994585
12/12/21 11:53 AM
12/12/21 11:53 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I can't find a listing for King throwout bearings. Is it listed as something else?
Re: Throw-out Bearing Recommendation - 23-Spline [Re: floyd] #2994586
12/12/21 11:54 AM
12/12/21 11:54 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Can't help you on manufacture but in case you didn't know, the bearing assembly needs to jive with your pressure plate choice. Diaphragm, Borg and Beck[ what our cars came with] and Long[ what Ford used] all take different overall length units. The Long style does not work with stock flywheels so most likely you don't have that but some aftermarket wheels can come drilled for it. The other two have the same bolt pattern. Whose cloth unit are you using? Maybe source from them?
Carl Kessel
Re: Throw-out Bearing Recommendation - 23-Spline [Re: CKessel] #2994630
12/12/21 01:41 PM
12/12/21 01:41 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks - I actually hadn’t thought about the need to match clutch and pressure plate styles Thanks for preventing me from making a bone-head purchase. I bought a RAM-92766 (Borg and Beck) 23-spline and am using a stock flywheel. I’ll check with RAM. I also see a US-made option on Brewer’s website.
Re: Throw-out Bearing Recommendation - 23-Spline [Re: floyd] #2994674
12/12/21 05:21 PM
12/12/21 05:21 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would give Passon or Brewers a call because they use what they sell and and they wouldn't install junk on customer cars.
twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Throw-out Bearing Recommendation - 23-Spline [Re: floyd] #2994677
12/12/21 05:29 PM
12/12/21 05:29 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
Press the old one off and call a bearing supplier with your old number to a US made bearing. twocents
Re: Throw-out Bearing Recommendation - 23-Spline [Re: fourgearsavoy] #2994707
12/12/21 07:30 PM
12/12/21 07:30 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Yep, will probably just call Brewers. Original set up is long gone so nothing to go on there. Thanks
Re: Throw-out Bearing Recommendation - 23-Spline [Re: floyd] #2994833
12/13/21 03:16 AM
12/13/21 03:16 AM
Boise
Moparteacher Offline
Boise
After installed with the clutch engaged and pedal up, make sure the bearing is NOT riding on the pp fingers. There must be clearance with a B&B/Long style.
Re: Throw-out Bearing Recommendation - 23-Spline [Re: floyd] #2994859
12/13/21 10:00 AM
12/13/21 10:00 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
We stock this one made in the USA
http://www.brewersperformance.com/proddetail.php?prod=CB1463
A833 4-speeds, parts & services
Re: Throw-out Bearing Recommendation - 23-Spline [Re: Dan Brewer] #2994865
12/13/21 10:20 AM
12/13/21 10:20 AM
MD
floyd Offline OP
floyd  Offline OP
MD
Originally Posted by Dan Brewer
Just ordered - Thanks
Re: Throw-out Bearing Recommendation - 23-Spline [Re: floyd] #2994872
12/13/21 10:42 AM
12/13/21 10:42 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Re: Throw-out Bearing Recommendation - 23-Spline [Re: 6PakBee] #2994914
12/13/21 01:53 PM
12/13/21 01:53 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
https://www.kingbearings.com/
Re: Throw-out Bearing Recommendation - 23-Spline [Re: jbc426] #2994927
12/13/21 02:26 PM
12/13/21 02:26 PM
moparx Offline
moparx  Offline
maybe called a release bearing ? shruggy
beer
Re: Throw-out Bearing Recommendation - 23-Spline [Re: moparx] #2994948
12/13/21 03:32 PM
12/13/21 03:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
beer
maybe because they sell engine bearings, not throwout bearings?
Re: Throw-out Bearing Recommendation - 23-Spline [Re: Sniper] #2996019
12/17/21 07:42 AM
12/17/21 07:42 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
beer
My bad. They don't carry roller bearings at all.
SKS and other roller bearing manufacturers carriy the replacement double sealed replacement bearing.
