WALL THICKNESS TOOL #2994103
12/10/21 05:00 PM
12/10/21 05:00 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi,
I know of sonic checkers, can i measure cylinder wall thickness (ball park) with a divider/caliper, 400 block has a big hourglass coolant hole so i can get in there
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: WALL THICKNESS TOOL [Re: 440lebaron] #2994110
12/10/21 05:14 PM
12/10/21 05:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted by 440lebaron
hi,
gary
No not and do a good job of it
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: WALL THICKNESS TOOL [Re: pittsburghracer] #2994118
12/10/21 05:38 PM
12/10/21 05:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
This worked good after the fact. biggrin Could also file this under not enough for 700ish HP either
Re: WALL THICKNESS TOOL [Re: Al_Alguire] #2994280
12/11/21 10:09 AM
12/11/21 10:09 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Lol awesome
Re: WALL THICKNESS TOOL [Re: Al_Alguire] #2994495
12/11/21 11:50 PM
12/11/21 11:50 PM
One of the first 400 block stroker pump gas motors I built was thinner (.035 shock whiney) than that piece is after boring it to 4.375 bore size down
The owner had it sonic tested by a shop close to where he lived, and he said they told him it was fine down
That block cracked the #1 cylinder wall on the cam side after 3 pulls, it made 489 HP at 5500 RPM on the second pull whiney
The whole side of that block was junk, I had a decent shop try to sleeve all four cylinders on the driver side, but it would't take, seal up, the sleeves down shruggy
That was a 1976 block.
Re: WALL THICKNESS TOOL [Re: Cab_Burge] #2994533
12/12/21 09:52 AM
12/12/21 09:52 AM
PA.
"Little"John
"Little"John
PA.
I have a mega block and assembly for sale now and “can it be bored to 4.500” is one of the first questions I get. When I bought it I already had a .055 over 440source kit and when I saw how nice the bores were at .030’i ordered a set of .030 pistons and had the assembly rebalanced. I wanted that extra meat
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
