Indy block #2993903
12/10/21 12:35 AM
12/10/21 12:35 AM
florida dade
cesar perez Offline OP
florida dade
Whats the max bore size on indy BB mopar aluminum block?
Re: Indy block [Re: cesar perez] #2994001
12/10/21 12:11 PM
12/10/21 12:11 PM
Texas
Chief Offline
Chief  Offline
Texas
Not sure this is the max, but their 655 cu in with a 5" stroke calculates to a 4.57 bore.
Just a FYI they have replacement sleeves at 150.00 each, last time I bought.
Dave Covey
Re: Indy block [Re: Chief] #2994133
12/10/21 06:51 PM
12/10/21 06:51 PM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
In Indy's catalog they state the '655' ci is a 4.840 bore center .... sounds like a good engine to start with beer
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Indy block [Re: Rapid588] #2994141
12/10/21 07:31 PM
12/10/21 07:31 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
If you have an existing block you need to sonic check it. They do not all come with the same sleeve thickness. IF you are ordering well 4.560 is the max that I have seen one. You simply run out of real estate. Todd
Re: Indy block [Re: Rapid588] #2994185
12/10/21 09:18 PM
12/10/21 09:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
4.84" bore space is for the 600-13 head only. They have no other head platform for that block. They arrive at 655 through "creative" rounding 4.563" bore 5" stroke. We have a 600-13 engine with a 4.84" BS block. A predator is generally done at 645" 4.530X5" but I know of two that ran the bore out further to 4.56 with a 4.80" block. Not what most woudl call ideal but it can and has been done.
