Re: Small block guys
[Re: justinp61]
#2992829
12/07/21 10:39 AM
12/07/21 10:39 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I'm not running a 6" rod but I would highly recommend Molnar, good service and nice parts!
68 Barracuda Formula S 340
[Re: RAY1969CARS]
#2994161
12/10/21 08:39 PM
12/10/21 08:39 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
What’s 6 inch rods are you using in your small blocks ??? Wont find many that arent running a longer rod. Standard is 6.123 Many run 6.200, 6.300 stuff. I ran 6.300 Compstars on the only ultra serious build i have had, very nice units. Cheap Callies
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2994705
12/12/21 07:15 PM
12/12/21 07:15 PM
Posts: 6,146 Melbourne , Australia
LA360
Which big end journal size are you going to be running? What Stroke? How much RPM do you intend on running? You might need to look at a Carillo or something similar. The Callies Compstar or Molnar stuff is nice for more budget friendly stuff.
Alan Jones
