Re: Differential Yoke- 7290
[Re: Cuda340]
#2992615
12/06/21 04:55 PM
12/06/21 04:55 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'd like to "spare you the obvious" but most all of them are the same yoke from the same foundry from what I've seen. Mancini has the middle of the road price at I think $135 Other suppliers sell the same yoke for more and some for less. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Cuda340]
#2993216
12/08/21 01:31 PM
12/08/21 01:31 PM
Posts: 5,894 Florida
Locomotion
There maybe three grades? Stock, Forged, Billet? I was under the same impression. I went to a 7260 billet yoke with u-bolts and solid Spicer joints after an OEM yoke "spread" & broke. Never a problem since then.
[Re: moparx]
#2993591
12/09/21 01:10 PM
12/09/21 01:10 PM
Locomotion
some have good luck using the 7260 joint/yoke combo, while others go to the big guy 1350 size. any idea where the sizes fit in with hp/tq in say, the average B body ? assuming a good yoke and solid joint ? Difficult to say because there's a lot more to it - weight, traction, torque, stick/auto, etc. Same situation with how well an 8 3/4 will hold up. (ring & pinion and caps). A heavier, dead-hooking, higher HP/torque combo will eventually find the weak link in the "chain" - output shaft, slip spline yoke, u-joints, driveshaft tube, rear end yoke, gears, caps, axles, wheel studs. My Dart at 3,540 + lbs pulls the wheels every run. Early on I found out the hard way that an OEM yoke can eventually spread, gets hammered from the movements & breaks, or just plain fatigue.
