LA headers on Magnum Engine #299191
04/25/09 07:38 PM
04/25/09 07:38 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Sunny, beautiful day, plenty of good intentions to drop my 5.9L in my little A-body...got a set of Headman headers...but these #W$%#@$?@# thing are hitting everywhere !!
Are they supposed to fit without troubles or they all need a lot of massaging like mine ?
THey still are hitting the steering column and the the lower part of the steering box near the K member........is this normal for this set up ?
Daniel
Re: LA headers on Magnum Engine [Re: Wedgeman] #299192
04/25/09 09:33 PM
04/25/09 09:33 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
what is the part number on the headers?
Tony
70 AARCuda Vitamin C
Re: LA headers on Magnum Engine [Re: 70AARcuda] #299193
04/25/09 09:39 PM
04/25/09 09:39 PM
GoDartGo Offline
GoDartGo  Offline
yes
Re: LA headers on Magnum Engine [Re: 70AARcuda] #299194
04/25/09 10:14 PM
04/25/09 10:14 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
PART IS 78050
Re: LA headers on Magnum Engine [Re: Wedgeman] #299195
04/25/09 10:17 PM
04/25/09 10:17 PM
a lot of instructions say you may need to dent stuff in a little bit to get a good fit.
Re: LA headers on Magnum Engine #299196
04/25/09 10:18 PM
04/25/09 10:18 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
a couple of dents !!!!!!! loll
Re: LA headers on Magnum Engine [Re: Wedgeman] #299197
04/25/09 10:20 PM
04/25/09 10:20 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
Hooker headers in my '71 Demon and '73 Scamp with a 5.9 Magnum. They hit the truck motor mounts on the engine (I slightly ground off the ears) and the end of the idler arm (slight dent in right header). Didn't hit the steering column or box. My cars are manual steering.
Re: LA headers on Magnum Engine [Re: VITC_GTX] #299198
04/25/09 10:34 PM
04/25/09 10:34 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Is the engine slighlty to the pass side of the engine bay or pretty centered ?
The pass side is very clear....
Re: LA headers on Magnum Engine [Re: Wedgeman] #299199
04/25/09 10:52 PM
04/25/09 10:52 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
passender side is always the easiest..
the engines are offsetted to the passender side to make room for the steering and etc.
Tony
Re: LA headers on Magnum Engine [Re: 70AARcuda] #299200
04/25/09 11:04 PM
04/25/09 11:04 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Thought so too....In that case I'll do more massaging tomorrow.....or msy be the engine is sitting too low.
Re: LA headers on Magnum Engine [Re: Wedgeman] #299201
04/25/09 11:09 PM
04/25/09 11:09 PM
V
VITC_GTX Offline
VITC_GTX  Offline
V
Mine only hits on the passenger side...strange.
Re: LA headers on Magnum Engine [Re: VITC_GTX] #299202
04/25/09 11:17 PM
04/25/09 11:17 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Anyone got pics of their engine mounts set up?
Re: LA headers on Magnum Engine [Re: Wedgeman] #299203
04/25/09 11:37 PM
04/25/09 11:37 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I have Magnum heads on an 83 318 LA block in my truck (83 D 250) and a set of hooker Super Comps madefor a 72-93 D/W series truck and a smallblock (P/N 5811) and they went right onto the Magnum heads w/o any problems.
Re: LA headers on Magnum Engine [Re: volaredon] #299204
04/26/09 09:00 AM
04/26/09 09:00 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I'm pretty sure I have Hedman ($99.00 Summit brand ones) in a 76 Volare with a 98' 5.9 in it. When I tell you that they "fell" in, I'm telling you that they didn't even have a scratch on them when I was finished. I did put a manual steering box in it tho.. Oh yeah, I ordered the headers for a late A body...
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: LA headers on Magnum Engine [Re: StandOnIt] #299205
04/26/09 09:05 AM
04/26/09 09:05 AM
on my 318 in my m body the headers hit on the wheel well on the pass side. i cut out a section of the inner fender and made a new panel that bubbled out towards the wheel a little bit. fits great now. i had to dent one of my tubes to get it to fit with my power steering on my fifth ave.
Re: LA headers on Magnum Engine #299206
04/26/09 10:24 AM
04/26/09 10:24 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I'll give it a try this afternoon,and post pics for your comments....
Mat be it is sitting too low...
Daniel
Re: LA headers on Magnum Engine [Re: StandOnIt] #299207
04/26/09 01:42 PM
04/26/09 01:42 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I've got those same hedmans in my 5th ave, fit no problem. I did tweak one pipe slightly on the drivers side, as it was awefully close to the starter. summits I think are made by flowtech, but same design, except the hedmans have a 1/4" flange, the flowtech/hooker/dynomax/summits all have 5/16". and the new hedmans have a ball collector.
if you're hitting the steering, make sure your engine mounts are good and not sagging, or try shim underneath them to bring the motor up a skoash?
2017 Grand Cherokee Overland
Re: LA headers on Magnum Engine [Re: patrick] #299208
04/26/09 05:01 PM
04/26/09 05:01 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Engine was sitting too low, now fits ok.!
This week is injection week !!
Thanks everyone !!
Daniel
