Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Fat_Mike] #2990559
11/30/21 04:48 PM
11/30/21 04:48 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
All D-Darts were white with red interior, you can stop right there is it is not. The normal 273HP is 235HP which this one seems to have. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Fat_Mike] #2990582
11/30/21 06:16 PM
11/30/21 06:16 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Originally Posted by Fat_Mike
[quote=dart4forte] Does this Dart have a 4 speed? If so it should have a 8.75 rear.
I had a '65] Dart GT, 273, 4 spd with a 7.25 rear. Not an apples to apples comparison, just wondering if something changed between '65 and '66? [/quote
In mid production year of 65 Chrysler was experiencing broken 7 1/4s coming in under warranty. They directed dealers to start replacing the broken 71/4s with 8.75rears. Ini turn NHRA made a rule change allowing stock/Superstock teams to run the 8.75. ddartdude has a copy of the directive posted on his web site.
Abe Lincoln
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Rhinodart] #2990584
11/30/21 06:16 PM
11/30/21 06:16 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
They also had heaters
Abe Lincoln
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: 67SATisfaction] #2990585
11/30/21 06:19 PM
11/30/21 06:19 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Originally Posted by 67SATisfaction
Originally Posted by slantzilla
Weren't all 273 engines before '67 solid lifter?
.. this appears true, even through 1967.
According to the book 'Chrysler Engines 1922-1998' by Willem L. Weertman (former Chief Engineer-Engine Engineering, Engineering Division, Chrysler Corporation, Feb 2006):
"In a cost-reduction move, the crankshaft material of both the the 273-cu-in LA and the 318-cu-in LA engines was changed from forged steel to nodular cast iron in 1967. For quality improvement and more consistent emission control, the tappets of the 318-cu-in LA engine were upgraded from mechanical to hydraulic during the same year, with the same change being made to the 273-cu-in a year later. For use with the hydraulic tappet, the valve rocker arms were changed from malleable iron castings, to steel stampings, similar in concept to the rocker arms used on the LB and RB big block engines."
Fun stuff.
- Art
1967 HiPo 273s had solid cams with the adjustable rockers.
Abe Lincoln
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Fat_Mike] #2990614
11/30/21 07:24 PM
11/30/21 07:24 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Interesting difference between the '65 and '66 273 4spd.
My brother's '66 GT is a console automatic. It does not have a 8-3/4 rear.
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: 67SATisfaction] #2990620
11/30/21 07:40 PM
11/30/21 07:40 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
The warranty covered the 4 speed cars. Not sure if you broke a 7 1/4 if they would cover that.
Abe Lincoln
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: dart4forte] #2991088
12/01/21 11:23 PM
12/01/21 11:23 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
8-3/4 behind a 235hp 273 and four speed was hit or miss in 1966. My old '66 Barracuda had a 7-1/4 when I got it. It had an 8-3/4 when I sold it...Nothing on the fender tag would tell you, as far as I know.
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Jim_Lusk] #2991137
12/02/21 03:41 AM
12/02/21 03:41 AM
I'm pretty sure Mopar did not start installing 8 3/4 in A bodies at the factories until 1967 scope
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Cab_Burge] #2991221
12/02/21 11:57 AM
12/02/21 11:57 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
The factory didn’t deliver 4 speed cars with the 8 3/4. However with increasing warranty claims of broken 7 1/4s on 4 speed cars the dealers received guidance to replace all the warranty claims with the 8.75. I would imagine as a customer you could walk into the dealer with a warranty claim and ask if they would replace the 7.25 with a 8.75. The 4 speed cars came with 8.75 rears in 66 while automatic cars still got the 7.25. Through the petitions of racers especially Junior Stock NHRA recognized this change and allowed racers change over to 8.75s regardless of power train. This subject has come up numerous times on classracer.com.
Abe Lincoln
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: dart4forte] #2991236
12/02/21 12:26 PM
12/02/21 12:26 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I dug out my copy of the TSB dated 18 April 1966 on the D/Dart. These cars came to the dealers who ordered the as a 699 special order. This number was stamped on the fender tag. The engine code was 32. The LO23 showed on the broadcast sheet.
The only deleated option for the interior was rear seatbelts
All cars came with WW1 paint and interior trim was P4H red
The cam was a Racer Brown grind using Hemi tappets
The carb was installed using a special spacer to allow for full opening of the butterflys. The stock 273 4bl manifolds had small bore openings that would allow the 1 11/16 butterfly’s to open. A Holley 4160, List 3778 was used. I belive this was the carb used on the race Hemi. Someone may correct me on that.
Engine used a 318 truck crankshaft
It mention an over the counter offer of an Edelbrock duel 4 manifold as well as an Edelbrock single 4 manifold. I assume this is the LD4B.
Also mentions the use of the 392 Hemi intake valve. No mention of the pistons so I assume they may of been TRWs.
Abe Lincoln
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Cab_Burge] #2991314
12/02/21 04:43 PM
12/02/21 04:43 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Every D/Dart had an 8-3/4...small bolt pattern, too.
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Jim_Lusk] #2991389
12/02/21 08:59 PM
12/02/21 08:59 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Abe Lincoln
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Jim_Lusk] #2991492
12/03/21 01:52 AM
12/03/21 01:52 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
So that said, what other (if any) 1966 Mopar A-Bodies came with an 8.75??? We seem to be getting conflicting info in this thread. Just kinda curious when and where the line was drawn. I guess what I'm asking is, definitively, did ANY '66 A-Bodies, other than the D-Darts, get born with an 8.75???
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Fat_Mike] #2991561
12/03/21 11:03 AM
12/03/21 11:03 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Yes, like I said, early in the production year (66) the dealers were directed to replace 7.25s on 4 speed cars that had problems under warranty. I’m not sure when they made the change on the assembly line. I’m sure that a few automatics made it through. As far as 67, I’m not sure but I would imagine the 4 speed cars continued to be delivered. I have another TSB somewhere in my stuff that addresses the warranty issues in 66.
Abe Lincoln
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: dart4forte] #2991663
12/03/21 02:02 PM
12/03/21 02:02 PM
moparx Offline
moparx  Offline
"It mention an over the counter offer of an Edelbrock duel 4 manifold as well as an Edelbrock single 4 manifold. I assume this is the LD4B."
what year did the 273 engines change the angle of the intake to head bolts ?
i had always thought the LD4B intake was offered after the 340 was introduced, and it was intended for it ? shruggy
i have been wrong before, so it wouldn't be surprising i'm wrong on this as well.
beer
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: dart4forte] #2991780
12/03/21 07:21 PM
12/03/21 07:21 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
In 1981 we dismantled a '67 Rallye Dart that had been in a head on in 1974. It was a 273 four barrel/auto with a 3.23SG 8-3/4. My old '66 Barracuda (273-4/4sp) had an SPD in October 1965. It left the factory with a 7-1/4. Known ownership history back to 1975. The 8-3/4 from the rallye Dart wound up in the Barracuda...
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: moparx] #2991781
12/03/21 07:22 PM
12/03/21 07:22 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
beer
Intake bolt hole change was for the 1966 model year.
Re: How can I verify a 1966 Dart GT 273HP? ..weird year for VIN [Re: Jim_Lusk] #2991971
12/04/21 12:50 PM
12/04/21 12:50 PM
moparx Offline
moparx  Offline
thank you Jim. up
beer
