90% throat rule? #2991208
12/02/21 11:38 AM
12/02/21 11:38 AM
Isle of Sheeps
Gtxxjon Offline OP
Gtxxjon  Offline OP
Isle of Sheeps
I bet that's got you wondering...
So I hear a lot of guys talking about this stuff, on NON Mopar sites...
I have often thought, ''what is too much port''?
So I dragged out a set of rusty 906's destined for the scrap bin and started to 'port in anger'!
Obviously I had some valves in mind for the ultimate porting jobbie.
2.225 intake and 1.880 exhausts.
I went this way after having a long conversation with Robert Landy and 'what his DAD DID'!
He said its all about the undershelf in the exhaust port which is easiest to remove with the 1.880, (all iron B/B heads)
If its good enough for the Landy's, them I'm all in... whistling
Right back to the 90% RULE, mainly for intakes???
Folks are saying if the 'bowl area is more than 90% of the seat area', you is making a good head BAD!!! ozbbq
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 90% throat rule? [Re: Gtxxjon] #2991235
12/02/21 12:24 PM
12/02/21 12:24 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Technically it’s 90% of the valve size. It’s all about proper sizing and maintaining the Venturi
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 90% throat rule? [Re: pittsburghracer] #2991250
12/02/21 01:04 PM
12/02/21 01:04 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I believe 90% would be considered on the conservative side. Depending on the head. I would think that if Landy came to 90% for 906's it would be a good place to at least start. But with the bowl opened past the throat size to create the venturi you could hit water in the 906 exhaust bowl. shruggy
Re: 90% throat rule? [Re: B1MAXX] #2991690
12/03/21 03:08 PM
12/03/21 03:08 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Darin Morgan covers this on his Youtube videos. I recall he said it varied from 88% on low lift cams (~.50") to 92% on Pro Mod engines with over one-inch valve lift. You will have to sit through a lot of other good info to get to the point he covers this. It's a wealth of info based on flow bench and dyno and track results.
Floyd Lippencott IV
