Re: Removing "cat" from older car?
[Re: Faust]
#2990861
12/01/21 01:43 PM
12/01/21 01:43 PM
Posts: 15,859 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I have a very low mileage '85 Caddy Seville. It is time for a new muffler and I am wondering about removing the catalytic converter. Will this make any difference? The car is severely underpowered and even 5 hp would be noticeable. Is there any other antique smog equipment I can remove? My state does not check cars this age. this is the 4.1, not the 8-6-4. I'd say yes especially if it's original CAT because it may be clogged. You could hollow it out and put it back on. Take a steel rod like piece of rebar and hollow it out or a piece of replacement pipe and you'll get a bit better flow but probably only notice the sound difference and not the extra hp.
Facts are stubborn things.
[Re: A12]
#2990957
12/01/21 06:51 PM
12/01/21 06:51 PM
Posts: 802 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
I know on the 80's Mopar there is only one O2 sensor pre-cat, my 88 CSX-T is cat-less and doesn't know the difference.
1972 Road Runner
1988 Shelby CSX-T
[Re: moparjim79]
#2990983
12/01/21 08:13 PM
12/01/21 08:13 PM
Posts: 10,558 Freeport IL USA
poorboy
Freeport IL USA
About the cats, I pulled a clogged cat off of my mothers Dodge minivan in early Nov, this year (she replaced it with a new one, her money). That OEM cat, at the junk yard, was worth $300, I suspect if I would have resisted a bit, I believe could have gotten more! Before you cut one up, might want to see what its worth scrap. Gene
[Re: poorboy]
#2991067
12/01/21 10:03 PM
12/01/21 10:03 PM
Posts: 2,386 Massachusetts
Faust
Massachusetts
About the cats, I pulled a clogged cat off of my mothers Dodge minivan in early Nov, this year (she replaced it with a new one, her money). That OEM cat, at the junk yard, was worth $300, I suspect if I would have resisted a bit, I believe could have gotten more! Before you cut one up, might want to see what its worth scrap. Gene Yes, I understand "factory" cats are worth a good piece of change. Aftermarket replacements, not so much. About the druggies someone else mentioned. Without a doubt. I live near a commuter rail station. Not safe to park a modern pick up there, they cut the cats off with a battery Sawzall.
[Re: moparjim79]
#2991075
12/01/21 10:14 PM
12/01/21 10:14 PM
Faust
Massachusetts
I can only speak from experience- parents had an 85 coupe de ville with the 4.1. Its a massive turd. You could do a bunch of stuff to it, but naturally aspirated its a dump box, and are infamous for rear main leaks. Yeah, no power, I think 150hp. That is why I was looking for even 5hp. Car & engine only have 60K, so far, so good. I like it (I know it is love it, or hate it) and may swap the engine when I have more energy. It looks like this one, except later alloy wheels. I just stole the picture, no idea about the other cars.
[Re: larrymopar360]
#2991247
12/02/21 12:58 PM
12/02/21 12:58 PM
Posts: 9,117 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
I'd say yes especially if it's original CAT because it may be clogged. You could hollow it out and put it back on. Take a steel rod like piece of rebar and hollow it out or a piece of replacement pipe and you'll get a bit better flow but probably only notice the sound difference and not the extra hp. We used to do this back in the day when cats got clogged up. They also used to sell "test tubes", pieces of pipe that bolted in to replace cats. Marketed as a diagnostic tool to run while you ordered a new cat. Guess how often the test tubes were removed...
[Re: Ramrod39]
#2991249
12/02/21 01:02 PM
12/02/21 01:02 PM
Faust
Massachusetts
[quote=larrymopar360
We used to do this back in the day when cats got clogged up. They also used to sell "test tubes", pieces of pipe that bolted in to replace cats. Marketed as a diagnostic tool to run while you ordered a new cat. Guess how often the test tubes were removed... Yeah, I remember those in the J.C. Whitney catalogs, remember those?
[Re: Faust]
#2991597
12/03/21 12:03 PM
12/03/21 12:03 PM
Posts: 19,396 north of coder
moparx
in my experience "unclogging" cats, most guys just do the "jam a pipe into them" pick out the big chunks, and call it done. then said "jammers" complain afterward the car ran better, but it's now back to where it was, or worse. the problem with doing this on the car [or off for that matter] is you get the big chunks, but not all of the material. what's left will eventually find it's way to the muffler, then clog it up, choking off the exhaust. the only sure fire way was mentioned above. take the cat off, cut open the top, remove the material, then weld the top back on. that way, you can be sure all the material is gone. or get a "test pipe" [made or bought] installed. i have fixed too many "jammer" repairs over the years, and heard them cry about buying new mufflers. anyone that talks about punching out cats these days, i just tell them to not come back complaining to me when the car starts to run worse than before.
[Re: Faust]
#2991636
12/03/21 01:24 PM
12/03/21 01:24 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
When I read the title of this thread a totally different image went through my head. A long time ago my wife's brother asked thier dad if he could borrow his car to go on a date. Dad said you have a good car , take it. He said but my car stinks real bad I can't take it on a date. Dad says let's find out why it stinks. They opened the hood and there was a dead cat laying on the intake manifold. Dad tried to pull the cat out by the leg and the leg just pulled out like an overdone turkey drumstick.
[Re: GomangoCuda]
#2991766
12/03/21 06:49 PM
12/03/21 06:49 PM
Faust
Massachusetts
When I read the title of this thread a totally different image went through my head. A long time ago my wife's brother asked thier dad if he could borrow his car to go on a date. Dad said you have a good car , take it. He said but my car stinks real bad I can't take it on a date. Dad says let's find out why it stinks. They opened the hood and there was a dead cat laying on the intake manifold. Dad tried to pull the cat out by the leg and the leg just pulled out like an overdone turkey drumstick. When I was a kid, I found a cat trapped between my battery and the hood.
[Re: Faust]
#2991831
12/03/21 10:00 PM
12/03/21 10:00 PM
Posts: 4,796 Castlegar, BC, Canada
That AMC Guy
I had no choice but to remove the cat from the '88 Dodge Ram V6 I've been putting back together. Not only did the truck not come with a cat, an OE one is not available and aftermarket ones are pointless since the truck is over 25 years old and exempt! Some vehicles, it's as easy as cutting them out, and welding in pipe. Some vehicles, like my Ram, had an air tube run from the air pump and not only pumped air into the manifolds, it pumped air into the cat as well. These are the ones you gotta watch out for because you don't want those air pipes turning into exhaust leaks. Since my air pump was also gone, I figured I'd delete the tubing and plug off the manifolds. Well, those plugs would've wound up being really odd sizes and drilling the holes bigger in my case, just wasn't an option. Not only that, a y-pipe for the V6 Ram is unobtainium. But I could find a y-pipe from a Dakota.... but that necessitated finding Dakota manifolds. THAT actually turned out to be a stroke of luck because '94-and-up manifolds no longer have the air injection ports. But then, I needed a Dakota trans dipstick tube. because the one for the Ram manifolds ran right where the Dakota manifolds run. Ugh. What a debacle. Luckily it all worked out in the end.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: moparx]
#2991912
12/04/21 08:52 AM
12/04/21 08:52 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
in my experience "unclogging" cats, most guys just do the "jam a pipe into them" pick out the big chunks, and call it done. then said "jammers" complain afterward the car ran better, but it's now back to where it was, or worse. the problem with doing this on the car [or off for that matter] is you get the big chunks, but not all of the material. what's left will eventually find it's way to the muffler, then clog it up, choking off the exhaust. the only sure fire way was mentioned above. take the cat off, cut open the top, remove the material, then weld the top back on. that way, you can be sure all the material is gone. or get a "test pipe" [made or bought] installed. i have fixed too many "jammer" repairs over the years, and heard them cry about buying new mufflers. anyone that talks about punching out cats these days, i just tell them to not come back complaining to me when the car starts to run worse than before. Some people are lazy, you gotta jam that pipe through, then drop it a few times, then jam it again, don't stop until you can see clean metal around the edges lol. Or so I have heard.
68 Barracuda Formula S 340
