Engine swap question? #299026
04/25/09 02:10 PM
04/25/09 02:10 PM
NY
71Dart6Pack Offline OP
NY
My Dart is going from a 225 /6 to a 340.
1. Will the /6 starter work with the 340?
2. Can I use the fan off the /6 on the 340?
Thanks.
Re: Engine swap question? [Re: 71Dart6Pack] #299027
04/25/09 02:15 PM
04/25/09 02:15 PM
(1) yes (2) yes but it's a 4 blade & might not pull enough air but do use a shroud.
Re: Engine swap question? [Re: 71Dart6Pack] #299028
04/25/09 02:18 PM
04/25/09 02:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Starteer will fit but may be a lower power rating than a V8 starter. May have been replaced at sometimse though so who knows, may work fine. Cost nothing to try it.
Fan will fit but may not pull enough air to cool properly.
