Back story. Came home last month and when I pulled into the driveway a big blue puff of smoke came up out of the right side of the engine compartment. Car was not charging at that point so I took the alternator out and had it test, it is bad.
So, I buy a new one (dual terminal) and install it. Car wont even start, no nothing. I start checking connections and the blue wire on the second bulkhead connector, bottom left had bubbled and melted. So, I cleaned the connection and it started. Now it is not charging and left me stranded last night.
I am not sure where to start checking with my voltmeter. there is voltage at the alternator main post (11.69) voltage at the field (10.74) , voltage at the ballast resistor (left 11.22) (right 8.05*****) and voltage at the regulator (10.72 Fld) (11.22 Ign)
The 8.05 off the ballast resistor scares me but I am not sure what it should be. It is reading 2.0 ohm.
Thoughts?
