Please school me on Mopar electric grounds #299007
04/25/09 01:33 PM
04/25/09 01:33 PM
MA
limelight440 Offline OP
MA
Basically wondering what grounds the dash & rear lights (rear lights have power)
But only illuminate when I dedicate a hard GND from the battery
Do the tail lights need a ground harness (yearone KJ215)
I thought the dash harness would have a dedicated GND
Fuel gage is working
Thanks, Mike
Re: Please school me on Mopar electric grounds [Re: limelight440] #299008
04/25/09 01:46 PM
04/25/09 01:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Dash grounds through it's mounting screws normally. Some tail lights need a ground from the housing to the rear body panel. Best bet is check out a wiring diagram for your specific vehicle.
Re: Please school me on Mopar electric grounds [Re: stumpy] #299009
04/25/09 06:39 PM
04/25/09 06:39 PM
MA
MA
Well, I can make it ground no prob....
I was under the impression that there was a
harness ground for the dash.
70 RR....The rear light harness (new from year one)
I noticed this week it has a ground terminal for each brake light (4)
leading me to think there is a ground harness
I should note, that due to this cars condition
(stripped for paint) when I bought it, I never
saw 1 wire "on" the car
Re: Please school me on Mopar electric grounds [Re: limelight440] #299010
04/26/09 07:03 PM
04/26/09 07:03 PM
michigan
black64 Offline
black64  Offline
michigan
Easy way to tell if you need awire to ground or if the lamp assembly is body ground is the lamp sockets and how many wires they have. A dual element bulb should have three wires if the assembly is not body ground and two wires if it is body ground. If it has three wires you need a ground some where in the rear lighting harness. If it has two wires you need a good body ground lamp assembly to body and good body to negative batt. Same with a single element buld one wire is case ground two wire is lamp harness wire to ground.
