Reproduction 2806070 Fan Clutch & 2863216 Fan Blade #2988519
11/23/21 11:23 PM
11/23/21 11:23 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
Found a glitch on the Fan Clutch..Don't have an Original to verify the Stud treads
https://youtu.be/HPiOekMlWXs
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: AARCONV] #2988533
11/24/21 12:00 AM
11/24/21 12:00 AM
New State
kidmopar Offline
kidmopar  Offline
New State
I believe this guy is correct ! Coarse thread into the fan clutch and fine thread attaching fan to clutch .........
My question is ..... Is this from Tony's Parts ? work shruggy
where did he get the fan clutch ? ? ? shruggy
* UPDATE * ....... The guy bought from Classic Industries as they "matched" Tony's price ..............
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: kidmopar] #2988557
11/24/21 07:15 AM
11/24/21 07:15 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
P65 warnings are an indicator of the country of origin.
China is the enemy.
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: 1972CudaV21] #2988601
11/24/21 10:29 AM
11/24/21 10:29 AM
VA
dragon slayer Offline
VA
I don't know if they changed over years, but those studs not correct either. It is fine/fine one continuous stud for fan blade to clutch. No unthreaded section. Place bolts attached the clutch fan to the water pump hub.
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: dragon slayer] #2988678
11/24/21 04:09 PM
11/24/21 04:09 PM
WV
Little Detroit Offline
WV
dragon slayer you are wrong those studs are correct.
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: Little Detroit] #2988953
11/25/21 11:43 AM
11/25/21 11:43 AM
VA
VA
I don't think so. Is that your kit you are selling? Go to page 2 and you can see a previous discussion on this. I have taken 4 or 5 originals apart and they are all thread fine. But like I said if some later version revised so be it, but I have never seen one.
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: dragon slayer] #2990244
11/29/21 06:25 PM
11/29/21 06:25 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Same issues on
66-70 B Body Accel Pedal Studs - original were fine thread, reproductions are coarse. WTH
70-71 E Body Shaker Trim Rings - original were fine thread, reproductions are coarse. Again, WTH
Why would companies go through all that trouble and get these small details wrong? (Not that I know anything about the fan clutch bolt pitch)
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: AARCONV] #2990255
11/29/21 07:19 PM
11/29/21 07:19 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have two originals in the shop, fine thread continuous threaded studs.
But!
I also have another vintage one here, old parts store replacement. No maker ID, 'Made in USA' (but a longer part number than Mopar used) and this one has coarse thread bolts.
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: Alaskan_TA] #2990821
12/01/21 11:57 AM
12/01/21 11:57 AM
VA
VA
Agree looked at some more and there are different versions probably over counter types from the day and they are course bolt.
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: Alaskan_TA] #2992135
12/05/21 12:00 AM
12/05/21 12:00 AM
Ashland City, Tennessee
Aar1064 Offline
Aar1064  Offline
But!
I have an original and just pulled the stud for this thread. Entire stud is fine thread.
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: Aar1064] #2992293
12/05/21 03:27 PM
12/05/21 03:27 PM
VA
VA
Funny how the original poster has disappeared from this topic. He seemed to want a concourse piece. It seems the consensus is they are fine thread all studs.
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: dragon slayer] #2993031
12/07/21 08:48 PM
12/07/21 08:48 PM
New State
kidmopar Offline
kidmopar  Offline
New State
I guess that's what I'm taking that away from all the posts here ??? shruggy work
I'm assuming you can obtain correct hardware either way to put it all together ? yellow
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: kidmopar] #2993331
12/08/21 07:28 PM
12/08/21 07:28 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
Still here..just when you flip the "correct" studs around to use the fine side , the stud sticks out a tad. But I did help out those Purist People out there..numbers matching and All...
Bottom line is Reproductions are similar but could not be correct
Re: Reproduction 2806070 Fan Clutch & 2863216 Fan Blade [Re: AARCONV] #3008388
01/23/22 11:00 PM
01/23/22 11:00 PM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
If you are going for OEM correct you will need to have an original clutch restored. The studs are a minor issue when you are looking at the reproduction fan clutches. Reproduction on the left, original on the right. The extra stud mounting shoulders are VERY visible when looking down at the fan when installed in the car.
So, all of the judges who peruse these pages, add this one to your hit list for the 2022 season..... grin
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
