Re: Unique battery mount question... [Re: AndyF] #2987938
11/22/21 05:51 PM
11/22/21 05:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by AndyF
That was the conclusion I came to with my Duster. My car sits in a heated garage so no need for a dump truck battery. I don't use the car as a snow plow or a tow truck, it only gets fired up on nice days so no need for a bunch of cold cranking amps. I measured how long the battery took to recharge after starting and it was typically less than 3 minutes.
Andy, my friend in southern Arizona uses $25 lawn tractor batteries in all his old cars. Even his 430 Lincoln. They all start because it is never winter there.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Unique battery mount question... [Re: AndyF] #2988163
11/23/21 11:08 AM
11/23/21 11:08 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I used a small racing battery in my Duster and built a small tray for it that mounted in roughly the stock location. I decided that it made a lot more sense to put a small battery up front than a regular battery in the trunk. When you weigh all the extra cables, switches and stuff it works out to be less weight to have a small battery up front.
Andy what's the compression on that engine, is that a Braille 15/18 battery? I know you no longer have the car, but how was it holding up?
Re: Unique battery mount question... [Re: Hemi_Joel] #2988168
11/23/21 11:18 AM
11/23/21 11:18 AM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
What charger do you use?
Re: Unique battery mount question... [Re: racerx] #2988187
11/23/21 11:57 AM
11/23/21 11:57 AM
AndyF Offline
AndyF  Offline
It was a 10:1 512. I don't remember the part number on the battery but it worked just fine. Only issue was that you needed to let the alternator charge the battery before you turned it off and restarted again. Which typically is no problem but you wouldn't want to start the engine, move the car a few feet, start the engine move the car a few feet kind of thing since you could eventually drain it.
Re: Unique battery mount question... [Re: Hemi_Joel] #2988192
11/23/21 12:07 PM
11/23/21 12:07 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by Hemi_Joel
Roger, if you have an alternator, I don't see why you would need that big group 24. 900 cranking amps from the little 4 and 1/2 lb, $350 ATX 20 is more than enough for any racing engine. Unless you are ice racing in Beulah North Dakota when it's 30 below. wave
I'm was thinking strictly street applications and looked at the direct replacement for a group 24. As to me going racing, I'm too old with crappy reflexes! grin
Re: Unique battery mount question... [Re: AndyF] #2988387
11/23/21 07:18 PM
11/23/21 07:18 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thanks Andy up
Re: Unique battery mount question... [Re: cudadoug] #2989534
11/27/21 10:50 AM
11/27/21 10:50 AM
Mo.
racerx Offline
racerx  Offline
Mo.
How low of cranking amps are you all getting away with battery mounted in the trunk, with and engines that has around 13.1 static compression with a alternator?
Re: Unique battery mount question... [Re: AndyF] #2989634
11/27/21 04:48 PM
11/27/21 04:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That doesn't really sound optimal for a drag car that you would start and stop probably a dozen times in day of racing. I would really be mad if I got ready to move out of staging lanes and into the water and the car wouldn't start after a few stop start cycles from the trailer to the lanes. But I guess if you push your car everywhere it wouldn't be an issue shruggy
Gus beer
64 Plymouth Savoy
Dana 60
