Engine oil pan gasket best choice ?
#2987900
11/22/21 04:25 PM
11/22/21 04:25 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
Hi all , having some minor weepage issues with my 440 oil pan , couple bolts loosening etc . Currently have rebuild kit cork/rubber gasket . Which of the Felpro gaskets would be prefered / better - #1808 fibre core or # 1834 steel core ? I have both , there is no Superformance supplier here in Australia . I am using a World block . Tried ARP bolts , back to factory which seem to hang on better . I am running a solid driver mount with strut . I have a Milodon oil pan . I have a race meeting in 2 weeks then a interstate meeting which will involve a 14 hr drive each way . Thanks
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Engine oil pan gasket best choice ?
[Re: MarkZ]
#2987966
11/22/21 07:06 PM
11/22/21 07:06 PM
tex013
Sydney,Australia
thanks Lew . Thanks Mark , yeah i'd like those but getting Mancini to pull their finger out for shipping is difficult at the moment .
Tex
[Re: tex013]
#2988031
11/22/21 09:40 PM
11/22/21 09:40 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2988033
11/22/21 09:43 PM
11/22/21 09:43 PM
tex013
Sydney,Australia
Cab , thought of that but its a real pain with road race pan and stock K frame . Pan gasket is thin as paper . Also fuly noticed 4 bolts intersect with the cap cross bolts so thread sealer in there
Tex
