99 Ram V10 thermostat
#2987005
11/19/21 10:29 PM
11/19/21 10:29 PM
Posts: 486 Sonoran desert, Arizona, USA
moparjo68
Hoping someone will know the Mopar part number for a 195 degree thermostat to fit a 99 ram v10 2500. It is definitely NOT part number 52028185AC that rockauto has listed in their v10 thermostat lineup. The thermostat I need fits down into a 3 inch metal seal. Its a very odd setup. I am not looking for aftermarket part numbers.
Re: 99 Ram V10 thermostat
[Re: moparjo68]
#2987022
11/20/21 12:04 AM
11/20/21 12:04 AM
Posts: 131 Conroe , Texas
iapco103
Conroe , Texas
Try p/n 53041087AC. It looks like what you are describing. Paul TRW1982 is correct, the p/n is 53041078AC , I typed it in wrong
[Re: moparjo68]
#2987182
11/20/21 02:36 PM
11/20/21 02:36 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Hoping someone will know the Mopar part number for a 195 degree thermostat to fit a 99 ram v10 2500. It is definitely NOT part number 52028185AC that rockauto has listed in their v10 thermostat lineup. The thermostat I need fits down into a 3 inch metal seal. Its a very odd setup. I am not looking for aftermarket part numbers. I tried looking for a factory T stat for my 99 V10 2500 Ram (so little support for these vehicles aftermarket or factory), everything that was supposedly factory PN#'d that I bought of Ebay ended up in the trash because it didn't fit, the best results I've had is with the Murray brand T stat set up from AutoZone/O'Riely's (been running it about 3 yrs now, no issues)....it is quite an oddball set up, if you haven't change one before there's 3 pcs required, the 6 bolt housing gasket, the T stat and the large ring seal that's pressed into the manifold under the T stat... you'll need a few slide/seal pullers to pop the factory cast brass T stat and ring seal...fun job! Mike
[Re: moparjo68]
#2988658
11/24/21 02:16 PM
11/24/21 02:16 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
My 96' Ram V10 had the black plastic housing originally. I bought a replacement cast aluminum housing back in the early 2000's. I think it was $90.00+ back then from the dealer.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: J_BODY]
#2989213
11/26/21 07:06 AM
11/26/21 07:06 AM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
If the tstat housing and timing cover are free of corrosion you’ll make $$ on that Actually, I was referring to things maybe I should be buying if I find it cheap as I recently purchased a V10 truck. Otherwise, people be makin' $$ on me!
