Tricking timing light to work on MSD
#2986764
11/19/21 12:56 PM
11/19/21 12:56 PM
Posts: 1,704 central il.
second 70
central il.
A friend brought over a cheap Harbor Freight dial back timing light that he said worked fine with MSD on his car. So I hooked it up to mine and it was useless. So I tell him it didn't work but I heard a trick that if you hook it up to a spare battery and not the one in the car it might work? He laughs and says that's the way he always uses it since his battery is in the trunk. Sure enough hooked it up to spare battery and it worked perfect. Here's the light. https://www.harborfreight.com/timin...J5u-k9AIVY3NvBB20QQlJEAQYASABEgJ-TPD_BwE
Re: Tricking timing light to work on MSD
[Re: TJP]
#2986815
11/19/21 02:24 PM
11/19/21 02:24 PM
Posts: 20,762 A collage of whims
topside
A collage of whims
Interesting - never thought of that. But I'm still using a simple timing light that dates back to the Nixon administration Dead simple & idiot-proof, works on anything...
[Re: second 70]
#2986844
11/19/21 03:08 PM
11/19/21 03:08 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I've done the same thing on my S/P car with a 7AL2, never thought about it not working but now this pointed out I will do that on any car I need to time with MSD ignition. I do remember having issues with a Penske dial back light years ago and ended up buying battery powered brand to use on MSD, now they both work Thinks for the tip
[Re: moparx]
#2986927
11/19/21 06:16 PM
11/19/21 06:16 PM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I wonder if I’ve never had trouble with the ones I’ve tried because I get power by my starter. 🤔
[Re: pittsburghracer]
#2986975
11/19/21 08:56 PM
11/19/21 08:56 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Same here...Never an issue with my Snap-on light...
...FAFO...
[Re: skicker]
#2987043
11/20/21 12:54 AM
11/20/21 12:54 AM
Posts: 20,175 Park Forest, IL
slantzilla
Park Forest, IL
Same here, no issues with my Snap On, but it's not a dial back. My battery is in the trunk also, and no alternator.
[Re: 360view]
#2987073
11/20/21 07:34 AM
11/20/21 07:34 AM
Posts: 20,172 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Interesting discussion.
This has me wondering if the circuits inside a “dial back” timing light could be used to create a device to retard ignition tming while driving the vehicle.
Long ago MSD actually sold an aftermarket box that could retard timing up to 20 degrees using a knob mounted below the dash. Get a Grid ignition. Guys are cheating with them every week at the racetrack with them.
