Re: Push rod length question.
[Re: JohnRR]
#298625
04/30/09 10:04 AM
04/30/09 10:04 AM
Posts: 15,487 Florida
scratchnfotraction
I have had more than a few hot and have the ticking sound "metalic sounding" pinging sound from the heat cycle cool down the engine its self is ping not the valves same as headers would make noise the inside of the engine will do the same thing check for the right pr IMO
[Re: scratchnfotraction]
#298626
04/30/09 10:57 AM
04/30/09 10:57 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
IMO .025 or even .100 differance in push rod length could be adjusted for with the adjustment screw of most aftermarket roller rockers . if i am wrong ,maybe some one could chime in and explain why .
1969 Dodge Charger
1969 Dodge Superbee
[Re: jhkintx]
#298627
04/30/09 11:18 AM
04/30/09 11:18 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
No frustration with any responders to my question. I truly value the experiece of this forum and appreciate all that respond.
So, If I target lifter bleed down as a starting point would this indicate pushrods that are too short or too long?
Thanks,
The pushrods would be too long , think about it if they were too short they wouldn't hold the valve open when they were supposed to be closed .
How many miles on the lifters , they shouldn't all be bleeding down that quickly as some valves are supposed to be open when the engine is shut off so that will tell me there is a lot of clearance in the plunger to body ???
[Re: cjs69mope]
#298628
04/30/09 11:21 AM
04/30/09 11:21 AM
JohnRR
U.S.S.A.
Yes it could if they are too short , too long the .025 yes but not the .100 , typically you want 2 to 3 threads of the adjuster below the rocker body , more the pushrod is too short , less it's too long and will cause issues including blocking the oil path to the pushrod adjuster contact point.
[Re: JohnRR]
#298629
04/30/09 11:47 AM
04/30/09 11:47 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
where did he say he was using aftermarket rockers? he's using magnum heads, OEM (non adjustible pedestal mount) rockers are 1.6 ratio.
[Re: JohnRR]
#298630
04/30/09 11:56 AM
04/30/09 11:56 AM
Posts: 229 Carmel, IN
jhkintx
Carmel, IN
Thanks,
The lifters (comp cams) were new when installed, they have less than 2000 miles on them. When I finished the head converstion I took the car to a mopar shop in Texas for a tune up. The mechanic (an old time mopar guy) said all was good except for the timing; he couldnt get the timing marks to show up so he set be feel. I assumed since this guy had a great reputation that I had the best tune for what I had. I'm not to sure anymore and just want to get the most out of the mods. This set up on a hot humid Texas day dynoed at 237 RWHP. I was told that was respectable and left well enough alone. At this point I just want to be sure all is good inside.
[Re: jhkintx]
#298631
04/30/09 01:32 PM
04/30/09 01:32 PM
Posts: 1,178 Indy
FlyFish
Indy
Why not just pull a valve cover and take a peek?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: patrick]
#298633
04/30/09 01:47 PM
04/30/09 01:47 PM
JohnRR
U.S.S.A.
I was thinking the same thing , I left out at the end of reply ...
This is all well and good but doesn't help the thread starter since he didn't say he had adjustable rockers ...
[Re: JohnRR]
#298635
04/30/09 02:57 PM
04/30/09 02:57 PM
scratchnfotraction
it is a slider cam and you better look at the lobes and lifters maybe might be the quik bleed down of the lifters and valves shuting could explane down on power and rough idle but again if it did not line up...a damper could have sliped what kinda chain and gears it got for timming? are they set up correct? reatrd..advanced...striaght up? what springs ya runnin on the mag heads? whats the spring seat rate?
#298636
05/01/09 06:34 AM
05/01/09 06:34 AM
jhkintx
Carmel, IN
As for the timing chain; it is a generic Auto Zone item "straight up". I cannot answer the spring and spring rate question, when I had my heads done I gave them the cam specs and they said it would be taken care of.
[Re: jhkintx]
#298637
05/01/09 07:53 AM
05/01/09 07:53 AM
scratchnfotraction
vauto zone china crap straight up have you tryed pulling the vc and chcking it with them off? sound like that would be my next trick maybe alittle messy if the engine is clean,but would rather have an oil stained engine than a broke one I cant figure the "can feel it" part and 30 sec is a long time to "feel" the vc ticking I would just check to see if all the rockers are moving about the same,give the springs a looky see for any broke ones maybe do you trust the machince shop that said it would be taken care of? if they left stock mag springs on that cam they might be a prob in Houston I would also pull #1 plug and bring it up to TDC and check dist/cap/rotor/wires/damper to see if its off time...I dont like the cant line it up thing....junk t-chain and gears could be off it could be the damper has slide and marks not lining up I guess by feel he ment "feeling the piston down the plug hole" and setting the dist/oil drive in fase with the cam IMO..get it up to temp and then pull the vc,run and shut down and
