Push rod length question. #298605
04/24/09 10:12 PM
04/24/09 10:12 PM
Carmel, IN
jhkintx Offline OP
jhkintx  Offline OP
Carmel, IN
If my pushrods are too long what behavior can I expect from the engine?
Currently I have a vacuum leak that I can't locate and when I turn off the engine you can hear the valvetrain clicking. Also, with a 2400 stall converter and 3:91 gears the car is a little weak out of the hole and idles rough (rougher than one would expect). Below is a list of mods.
1) Stock 70 318 short block
2) Magnum heads milled .040
3) Mopar thin head gaskets
4) Mopar 7.625 pushrods
5) Mopar cam 280/474 (lift is 505 with 1.6 rockers)
6) Edelbrock Perf intake
7) Holley 600 vac sec
Re: Push rod lenght question. [Re: jhkintx] #298606
04/24/09 10:37 PM
04/24/09 10:37 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Too long and the hydraulic lifters will be at the bottom portion of their range. The worst case scenario is they will be bottomed out and you will have no compression.
Re: Push rod lenght question. [Re: jhkintx] #298607
04/24/09 10:46 PM
04/24/09 10:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If the lifter pumps up it can hold the valves open
(maybe just a touch) that would give you the rough
idle and the lack of performance. Also the intake
leak can give you both the idle issue and lack of
power
Did you use a push rod length checker to determine
the length needed
Re: Push rod lenght question. [Re: jhkintx] #298608
04/25/09 01:46 AM
04/25/09 01:46 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
You can burn a valve if the it is incorrect for too long of time.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Push rod length question. [Re: HealthServices] #298609
04/25/09 09:58 PM
04/25/09 09:58 PM
Carmel, IN
jhkintx Offline OP
jhkintx  Offline OP
Carmel, IN
I was told to add rocker shims and see if the lifters quit clicking. Does this make sense as a starting point for trouble shooting?
Re: Push rod length question. [Re: jhkintx] #298610
04/25/09 10:15 PM
04/25/09 10:15 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I don't understand the clicking when you turn the engine off. Are you real sure of what you are hearing????
If you have lifters clicking the push rods are to short not too long.
Re: Push rod length question. [Re: MoparforLife] #298611
04/27/09 01:37 PM
04/27/09 01:37 PM
Carmel, IN
jhkintx Offline OP
jhkintx  Offline OP
Carmel, IN
I'm 100% sure the clicking comes from under the valve covers; it is very distinctive "click, Click, Click" for about thirty seconds to a minute on both sides of the valvetrain.
Re: Push rod length question. [Re: jhkintx] #298612
04/27/09 01:53 PM
04/27/09 01:53 PM
Upper Midwest
Upper Midwest
New one to me. Any one else heard of this????
Re: Push rod length question. [Re: MoparforLife] #298613
04/27/09 02:59 PM
04/27/09 02:59 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
That clicking could be cooldown from headers or exh manifolds. I have heard that before. It is close to vc. Otherwise I'm baffled (make the home Improvement sound oah)
Re: Push rod length question. [Re: BELVEDERE67] #298614
04/28/09 02:10 PM
04/28/09 02:10 PM
Carmel, IN
jhkintx Offline OP
jhkintx  Offline OP
Carmel, IN
It is not cooldown from headers, you can feel the clicking with a hand on the valvecover. I'm shocked that with all the experience and wisdom I have a symptom that's unique...
Re: Push rod length question. [Re: jhkintx] #298615
04/28/09 03:03 PM
04/28/09 03:03 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
with the engine off, as you state in the first post???!!!
2017 Grand Cherokee Overland
Re: Push rod length question. [Re: patrick] #298616
04/29/09 08:42 AM
04/29/09 08:42 AM
Carmel, IN
jhkintx Offline OP
jhkintx  Offline OP
Carmel, IN
As soon as you shut down the engine, the clicking will last 30 - 60 seconds.
Re: Push rod length question. [Re: jhkintx] #298617
04/29/09 09:38 AM
04/29/09 09:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Kind of makes no sense , once you turn the engine OFF nothing is moving , so what's clicking ???
You could throw shims under it I guess , but if your rocker to valve tip geometry isn't off it may be so don't use them as the cure. But you have MAGNUM heads , they don't have a shaft mount system do they, shims go where? I'm lost on new smallblock stuff .
Re: Push rod length question. [Re: JohnRR] #298618
04/29/09 10:29 AM
04/29/09 10:29 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yeah, when the engine is turned off, nothing is moving, so I don't get where the noise would come from unless it's just the ticking of hot parts contracting when cooling? or maybe lifter bleed down closing open valves?
magnums are pedestal mount. shims could go between the pedestal and the head....
Re: Push rod length question. [Re: patrick] #298619
04/29/09 12:48 PM
04/29/09 12:48 PM
Backwoods of NC
Topher Offline
Topher  Offline
Backwoods of NC
It's cooldown from the exhaust.
Now start chasing why the car isn't performing as it should. First thing to do is run a cylinder leakdown test, that will tell you many things about your engine.
Topher
topher@headlightmotorman.com
www.headlightmotorman.com
67 Charger 383 3 pedal car
[|||||||||o|||||||||]
Re: Push rod length question. [Re: jhkintx] #298620
04/29/09 07:39 PM
04/29/09 07:39 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
The 7.625" long push rods on a LA/magnum hybrid tend to be on the short side. I had to go to 7.650" long ones to get proper preload on the lifters.
You can check how much you are preloading the lifters by loosing the bolts that hold the rocker pedastels to the head. Then turn them back down while spinning a push rod in your fingers felling for play. Once all the play is gone the bolt should turn between 1/2 and one turn before the pedestal bottoms on the head. The bolts are 5/16-18 so 1/2 turn is 0.027" of preload and one turn is 0.055". If you are in that range the pushrods are not to long.
I agree with the others that a clicking noise after shutting down the engine is not the valve train.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Push rod length question. [Re: Topher] #298621
04/30/09 07:51 AM
04/30/09 07:51 AM
Carmel, IN
jhkintx Offline OP
jhkintx  Offline OP
Carmel, IN
As stated earlier; the clicking is NOT cooldown from the exhaust. Wish I could fiqure out a way to post a video clip to validate my issue. After reading the responses so far; I could describe the clicking as possibly the sound of metal hitting metal under pressure. It is not easy to discribe unique sounds with text.
Re: Push rod length question. [Re: jhkintx] #298622
04/30/09 08:50 AM
04/30/09 08:50 AM
scratchnfotraction Offline
lifter bleed down and the valves clicking shut,IMO
runs like poop cause they are hanging open
Re: Push rod length question. [Re: scratchnfotraction] #298623
04/30/09 09:24 AM
04/30/09 09:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This would be the only plausible answer other than the sound the exh makes cooling down .
As far as the frustration of the thread starter , WE collectively are not in front of your car so there are only 1 or 2 possible answers since the engine is NOT RUNNING when this happens. no matter what we say you are going to have to get your hands dirty and start ripping into it because it appears you do not like the answers you are getting .
Re: Push rod length question. [Re: JohnRR] #298624
04/30/09 10:02 AM
04/30/09 10:02 AM
Carmel, IN
jhkintx Offline OP
jhkintx  Offline OP
Carmel, IN
No frustration with any responders to my question. I truly value the experiece of this forum and appreciate all that respond.
So, If I target lifter bleed down as a starting point would this indicate pushrods that are too short or too long?
Thanks,
