Speaking of new blocks #2986126
11/17/21 04:08 PM
11/17/21 04:08 PM
Texas
Chief Offline OP
Chief  Offline OP
Texas
What is the consensus. Have the manufacturer perform all the machining, or send the block to a machine shop of your choice to finish?
I had Indy do my first block but was wondering what every one else does.
Dave Covey
Re: Speaking of new blocks [Re: Chief] #2986131
11/17/21 04:30 PM
11/17/21 04:30 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
On mine, I prefer to finish the bore locally so we can fit the pistons real close.
Re: Speaking of new blocks [Re: Chief] #2986168
11/17/21 06:42 PM
11/17/21 06:42 PM
I had my KB finish machine by FHO so I could deal with one shop on both issues, new block and finish machining.
I had Bulldog do all the finishing machining needed for the same reason up work
I will have the piston maker match the bores on the blocks plus .0005 more up work grin
Re: Speaking of new blocks [Re: Cab_Burge] #2986338
11/18/21 09:33 AM
11/18/21 09:33 AM
an8sec70cuda Offline
KB did the machining on my block. They did a good job on it, but that was in 2006. Now it may be a completely different story.
I have a World block that I had my local machinist go over. It wasn't bad, it was only rough bored. Fresh bores and fresh line hone after replacing the junk fasteners and all is well.
CHIP
'06 GMC 2500HD LBZ Duramax
