miss matched intake and carb on a 318
#298541
04/24/09 09:36 PM
04/24/09 09:36 PM
Posts: 63 minnesota, USA
greenfire
minnesota, USA
well i ran the casting #off the intake manifold that the previous owner had installed on this 318 and it is from a 1978 360. and i suspect the therma-quad carb that is on there came with it. why would some one use such a miss matched combo as this? and wont that cause problems?
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: miss matched intake and carb on a 318
[Re: greenfire]
#298542
04/24/09 09:39 PM
04/24/09 09:39 PM
Posts: 565 IA
landon1
IA
easy way to gain some power off the stock 2 barrel...port sizes may not match up, but probably worked okay for whoever did it
'71 Satellite Sebring 440
[Re: landon1]
#298543
04/24/09 09:47 PM
04/24/09 09:47 PM
greenfire
minnesota, USA
well i do have a period correct edelbrock intake manifold and a edelbrock performer 600 cmf carb for it. i noticed that a vacuum line that goes from the carb <tq> that is currently on the motor and it goes to a canister with 2 more lines comming off of it? what is the canister for? and do i need it? is it part of the emissions/smog gear? thanks
[Re: greenfire]
#298544
04/24/09 10:05 PM
04/24/09 10:05 PM
Posts: 826 Stone Mt, GA.
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
All 4 bbl LA based 318 4 bbl engines had 360 intake and 360 heads. It was all oem from Mopar, David.
ThermoQuads:stock, street/strip and race;
800/850 cfm's, 860/910 cfm's and 1,000 to 1,060 cfm's.
New parts for all OEM 1971-1984, Competition Series and SuperQuad carbs and custom fabricating.
Carbs bought and sold. Consulting on pre-purchases
so you get the right carb the first time.
[Re: DEMONSIZZLER]
#298545
04/24/09 10:12 PM
04/24/09 10:12 PM
greenfire
minnesota, USA
but this wasnt a 318 that came stock with a 4bbl carb, it was a 2 bbl 318 according to the vin and tags i could find
[Re: greenfire]
#298547
04/25/09 08:03 AM
04/25/09 08:03 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Been done thousands of times. It works and the mismatch for what he was doing didn't matter.
[Re: Crizila]
#298549
04/25/09 11:39 AM
04/25/09 11:39 AM
Posts: 15,487 Florida
scratchnfotraction
swaped a many 360 intakes and carbs right on to a small port 318 head,"poormans upgrade" mix matched port size is not gonna be noticed for a street cruzer it is a slight gain in performance,contrary to what most will tell ya even swapping the 360 heads on to a stock 318 is a gain in performance, even though it will lower the comp some,it will make up for it in flow on the top end, early 80s mopar used it any way with a q-jet on all 4-v 318s main prob with a 318 is the 2-v carb and the wimpy cam hopfully the thermobog is from a sm block engine and not to big and all jetted wrong a mid 80s mopar q-jet will fit also,and easy to tune compaired to a thermobog...but when they work they are a good carb the 360 heads will have a big 360 cast in across the runners on one end of the head under a vc and yes see what cast # it has
[Re: 69L78Nova]
#298551
04/25/09 12:24 PM
04/25/09 12:24 PM
scratchnfotraction
my bad..your right it was 85 or so for the first q-jets I know the 85 are to be stayed away from,first yr probs and then feed back crap I allways take a mopar throttle lever from one and tac weld it to a early chivy q-jet so it fits with mopar linkage the early chivy ones are non emiss, a vac choke pull off and are easy to strip and modofry and have been close with the jetting when from a 67-74 327/350,only cost about 10$ for a rebuild kit I do grab needles/jets from the dodge q-jet and swap over to the chivy one some times as well to help get it jetted right works for me anyways
[Re: scratchnfotraction]
#298552
04/25/09 03:11 PM
04/25/09 03:11 PM
greenfire
minnesota, USA
thanks, i do have a early 70s edelbrock intake manifold and a edelbrock performer 600 cmf carb to put on so if heads are stock that should clear things up.
[Re: Mr.Yuck]
#298557
04/25/09 09:25 PM
04/25/09 09:25 PM
MoparforLife
Upper Midwest
318 intake is different. They are hard to find. I sold a LD318 eddy intake a few years ago for $225. good luck finding one.
LD4B is the intake made by edelbrock for the 273/318 heads. Great manifold.
