What radiator for street #2984890
11/13/21 05:49 PM
11/13/21 05:49 PM
Wisconsin
sjs64polara Offline OP
Wisconsin
Been many years since I put a radiator in a street vehicle. My 77 dodge truck will have about 750 hp and will be frequently driven on the street. What radiator do you guys recommend? I plan to use a separate cooler for the transmission . Thanks
Re: What radiator for street [Re: sjs64polara] #2984999
11/14/21 12:18 AM
11/14/21 12:18 AM
Copper and brass will outcool aluminum of the same size up scope
And probably last longer also scope
Re: What radiator for street [Re: sjs64polara] #2985005
11/14/21 01:00 AM
11/14/21 01:00 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
If there's nothing wrong with the original radiator I would start with that.
Guessing it is large dimension?
Re: What radiator for street [Re: INTMD8] #2985049
11/14/21 10:13 AM
11/14/21 10:13 AM
Washington
madscientist Offline
Washington
The biggest two core aluminum radiator you can find. The cores should be 1.00 inch minimum and 1.25 is better. You can’t get much bigger than that on the tubes because the radiator gets so thick it restricts air flow. Ignore the copper/brass cools better because it doesn’t in a correctly sized and built radiator. 4 small tubes don’t flow as well or cool as good as 2 big tubes. You can’t use big tubes with a copper/brass radiator because the materiel isn’t strong enough if you make the tubes that big.
Re: What radiator for street [Re: madscientist] #2985063
11/14/21 10:57 AM
11/14/21 10:57 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I'm running a Speed Cooling radiator/fan combo and it's the coolest my car has ever run.
https://speedcooling.com/
[Linked Image]Untitled by Greg Ault, on Flickr
Re: What radiator for street [Re: gsmopar] #2985177
11/14/21 05:12 PM
11/14/21 05:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
X2 on the Speed Cooling rad iagree Love mine and it fits really nice up
Gus beer
64 Plymouth Savoy
Dana 60
Re: What radiator for street [Re: fourgearsavoy] #2985194
11/14/21 06:08 PM
11/14/21 06:08 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We've ran the same big Be Cool aluminium rad in 3 combo's. 528, 580 and a 655, had it for 20 years now. On all of them you can watch the temp come down when the fans (Spal) kicks in up
Re: What radiator for street [Re: sjs64polara] #2985470
11/15/21 03:39 PM
11/15/21 03:39 PM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
Love the Truck!!!!
Re: What radiator for street [Re: sjs64polara] #2985481
11/15/21 04:28 PM
11/15/21 04:28 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
This one has worked pretty well for me for awhile now.
https://www.summitracing.com/parts/sum-380428
For the dollar spent and how few issues there have been with it, I can't complain.
Did have to weld on brackets.
Rich H.
Esse Quam Videri
Re: What radiator for street [Re: ZIPPY] #2985924
11/16/21 10:17 PM
11/16/21 10:17 PM
Wisconsin
Wisconsin
Thanks for the input……..
