Installing a late model Bosch alternator on my Cuda.... #298446
04/24/09 07:57 PM
04/24/09 07:57 PM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
I came across a late model 2002 Dodge Ram Bosch Style 130 Amp alternator.
I've been doing some research, and it looks like this is almost a direct swap, less the modification of the brackets and splicing the field wires into a late model oval connector and adding a fused wire from the Battery post of the alternator over to the starter relay post.
Is it really that simple? Has anyone else done this?
PS, the reason I want to do this is because I'm running electric fan, and amp, and I'm going to be adding a/c. I have the usual "dim light syndrome".
Thanks!
Re: Installing a late model Bosch alternator on my Cuda.... [Re: Cudalord] #298447
04/24/09 07:59 PM
04/24/09 07:59 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You will want to bypass your ammeter too..it is probably rated for a max of 50 or 60 amps going through it... (It is a good mod anyways..especially so if you are running an alternator that can put out double the current with enough draw on it then the ammeter is rated for)
Re: Installing a late model Bosch alternator on my Cuda.... [Re: OzHemi] #298448
04/24/09 08:09 PM
04/24/09 08:09 PM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
Ammeter is long gone:). Running Autometer gauges with Voltmeter.
Re: Installing a late model Bosch alternator on my Cuda.... [Re: Cudalord] #298449
04/24/09 08:17 PM
04/24/09 08:17 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
BTW...AndyF does the brackets for that too..
Re: Installing a late model Bosch alternator on my Cuda.... [Re: OzHemi] #298450
04/24/09 09:18 PM
04/24/09 09:18 PM
IN
ahy Offline
ahy  Offline
IN
Does the Bosch have a V belt or serpentine pulley?
Re: Installing a late model Bosch alternator on my Cuda.... [Re: ahy] #298451
04/24/09 09:42 PM
04/24/09 09:42 PM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
Serpentine, but I heard the GM V Belt Pulleys work on it. That's next on my to do list.
Re: Installing a late model Bosch alternator on my Cuda.... [Re: Cudalord] #298452
04/24/09 10:04 PM
04/24/09 10:04 PM
IN
ahy Offline
ahy  Offline
IN
Thanks for the pulley info... I'm watching the post since I have a similar problem.
Re: Installing a late model Bosch alternator on my Cuda.... [Re: Cudalord] #298453
04/25/09 12:55 AM
04/25/09 12:55 AM
AndyF Offline
AndyF  Offline
Denso 120 amp from 80's era van on a big block.
Re: Installing a late model Bosch alternator on my Cuda.... [Re: AndyF] #298454
04/25/09 12:56 AM
04/25/09 12:56 AM
AndyF Offline
AndyF  Offline
Here is a kit I did for a local guy. This is a big alternator from a late model Lexus.
Re: Installing a late model Bosch alternator on my Cuda.... [Re: AndyF] #298455
04/25/09 08:15 AM
04/25/09 08:15 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
do you have a kit that will work for air cond.
Re: Installing a late model Bosch alternator on my Cuda.... [Re: gtx69] #298456
07/29/11 12:24 AM
07/29/11 12:24 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Bump any one have a kit for factory air?
