Re: 70's bed conversion
[Re: moparmarks]
#2984161
11/11/21 03:43 PM
11/11/21 03:43 PM
moparpollack
Lil Herman
Lil Herman
85086
Has anyone changed a long wide box to a short box? 72-80 Do you mean cut the long bed down to a short bed? My buddy does chevys all the time I think you could do it with a dodge as well.
[Re: stumpy]
#2984250
11/11/21 08:04 PM
11/11/21 08:04 PM
Posts: 10,605 Freeport IL USA
poorboy
Freeport IL USA
I believe that would entail a frame rework. Yep, roughly 18" out of the long box frame between the wheel base, to accommodate the short box. If you don't have a short box to install, you will need to cut about 18" off the front of the 8' bed as well. You would be ahead of the game to find a short box truck if you really want a short box truck.
[Re: moparpollack]
#2984334
11/11/21 11:28 PM
11/11/21 11:28 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Has anyone changed a long wide box to a short box? 72-80 Do you mean cut the long bed down to a short bed? My buddy does chevys all the time I think you could do it with a dodge as well. Chevy boxes are bolt together where as Dodge boxes are welded together
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2984479
11/12/21 01:11 PM
11/12/21 01:11 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
There is a difference behind the wheel as well...4" shorter. Simply need to cut 16" (115 "wb from 131"wb = 16") from the frame rails between the front box mount and the start of the rear axle rise. then section the box similarly. For the rear frame rails (behind the axle) lop the frame off at the forward most bumper hole then remove the next 4” and weld the bumper section back on.Then section the rear of the box 4" from betwene the wheel tub and the rear box mount. More body work than frame work.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2985050
11/14/21 10:15 AM
11/14/21 10:15 AM
moparmarks
Well that is a game changer. I've always thought that they were the same on the back end. Guess I'm still looking for a nice short box and now have a nice long box for sale. Thanks guys for the info.
[Re: moparmarks]
#2986034
11/17/21 11:18 AM
11/17/21 11:18 AM
Posts: 1,357 central Florida
VL21
central Florida
It would be a long way to come get it, but a friend here has 2 Short beds, one real nice and one with a little rust in the front floor, otherwise good bed.
And he needs the money, his semi just blew up.
It takes gasoline to interest me.
[Re: mgoblue9798]
#2986949
11/19/21 07:07 PM
11/19/21 07:07 PM
moparmarks
Ya that is a bit far for me, thanks though. I live on the edge of the Southwest Desert so you would think I could find one around here? Nooooooooooo. There are a couple in CA but that is still a bit far.
