70 Air Grabbe Bezel ? #298355
04/24/09 03:54 PM
04/24/09 03:54 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I'm putting my dash together and I went to put the bezel on the air grabber switch and it isn't wide enough to go over the switch. Have I got the wrong swith are bezel? It's both original pieces. Any input will help. Thanks Ronnie in Okla.
Re: 70 Air Grabbe Bezel ? [Re: okie] #298356
04/27/09 11:52 AM
04/27/09 11:52 AM
White Plains NY
VitaminCRunner Offline
White Plains NY
I had the same issue, the switch goes through the dash from the back and the bezel mounts to the front of the dash. If you do a search on my screen name someone sent me photos of a dissabled dash showing how it mounts.
Re: 70 Air Grabbe Bezel ? [Re: VitaminCRunner] #298357
04/27/09 11:54 AM
04/27/09 11:54 AM
White Plains NY
White Plains NY
Re: 70 Air Grabbe Bezel ? [Re: VitaminCRunner] #298358
04/28/09 07:16 AM
04/28/09 07:16 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Thanks for the pictures, I figured out how to mount it. I had to get another front trim the plastic one and the air grabber hole in it was a 1/2 inche lower than the original so I'm going to have to cut it out some. This is what was really throwing me off on it. You would think they would have all been cut out the same. Now I've just got to figure out how to run the acuater and the hoses under the dash. Thanks Ronnie
