Re: 79 truck exhaust comparisons [Re: Moparite] #2980287
10/31/21 04:08 PM
10/31/21 04:08 PM
fredericksburg,va
cudaman1969 Online sleepy OP
cudaman1969  Online Sleepy OP
fredericksburg,va
Originally Posted by Moparite
Quote
can I convert the 92 overdrive trans to a non lockup converter? I want to use one of my regular loose ones.
Why do you want to do that? Just keep it from going into lock up.
But I’d have to use the stock lock up converter (low stall) and not a higher stock type stall
Re: 79 truck exhaust comparisons [Re: cudaman1969] #2982316
11/06/21 10:24 AM
11/06/21 10:24 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
A "lock up" converter can be used without it locking up(not engaging the lock up solenoid). If you want to put a high stall converter it will work(check compatibility) but it won't lock up. Lock up is = to 200 rpm so you will use more fuel during trips. Get a lock up high stall converter if you want both.
