Axle Flange Gasket #298125
04/24/09 11:05 AM
04/24/09 11:05 AM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
I ordered 2 axle flange gaskets from advance auto thinking they were the foam ones, but they are hard cardboardor plastic. Are these for behind the backing plate or can I use them in place of the foam ones? It is on an 8 3/4. Thanks
Re: Axle Flange Gasket [Re: Howard] #298126
04/24/09 03:44 PM
04/24/09 03:44 PM
steel shim between housing flange/backing plate & white foam between backing plate/axle flange. not sure what you have, can you post a pic.
Re: Axle Flange Gasket [Re: RapidRobert] #298127
04/24/09 04:20 PM
04/24/09 04:20 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
A7-RK Package
Re: Axle Flange Gasket [Re: Snoopy] #298128
04/24/09 04:42 PM
04/24/09 04:42 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Snoopy is that a deaaler package or?? I need to order a couple for my truck.
Re: Axle Flange Gasket [Re: 69DartGT] #298129
04/24/09 04:56 PM
04/24/09 04:56 PM
Snoopy Offline
Snoopy  Offline
I picked it up at a local parts store. They have been discontinued, but there are some still sitting on shelves. I made a lot of calls and finally came up with a parts store that had a set on the shelf.
P/N Left A7-LK, Right A7-RK
Re: Axle Flange Gasket [Re: Snoopy] #298130
04/24/09 06:20 PM
04/24/09 06:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Fel-pro #'s
white foam gasket - 13800
black metal shim gasket - 55032
Re: Axle Flange Gasket [Re: gtx6970] #298131
04/24/09 09:41 PM
04/24/09 09:41 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Rapid Robert is right it is a metal shim and GTX 6970 the gasket is #55032 felpro the foam one also can be ordered at Advance for 1.49 each. So I guess I'll order it and wait for it to come in before putting it back together. Thanks Howard
