MSD starters #2980763
11/01/21 11:59 PM
11/01/21 11:59 PM
Australia
Dartski68 Offline OP
Australia
Ive read on summit the MSD starters like part 5098 don't fit big blocks with 727. What starter motor is everyone using, Im running 11:1 compression ratio with 470cubes and decent size custom pipes
Re: MSD starters [Re: Dartski68] #2980972
11/02/21 04:43 PM
11/02/21 04:43 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i have used the same CVR for 10 or 12 years . Fitted factory and aftermarket block , 440 and 505
I know some order a Dakota 360ci startermotor and are happy with that .
Make sure there is air space or get a starter blanket/shield
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: MSD starters [Re: tex013] #2981056
11/02/21 07:58 PM
11/02/21 07:58 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I just used one for the same application as my old work van dodge2. 2002 2500 360 magnum.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: MSD starters [Re: 340SIX] #2981340
11/03/21 01:28 PM
11/03/21 01:28 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Yep. Starter from a 97 Dakota for a 5.2. Cheap.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
