Help with 66 monaco teardown #2980645
11/01/21 05:49 PM
11/01/21 05:49 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Pulling engine and trans in one shot. The trans crossmember appears to have the torsion bars seated or going through it. Is it possible to remove trans without relieving torsion bars and removing the crossmember. I havent seen this before i only know 68 up. Thanks for any help.
68 Satellite Wagon and a few other ones
Re: Help with 66 monaco teardown [Re: mro] #2980699
11/01/21 07:51 PM
11/01/21 07:51 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Been too many cars and too many years to be sure, but I don't ever remember doing anything with torsion bars when pulling a trans. Trust, I've pulled a lot of transmissions. Pictures may help jog the old memory though.. Gene
Re: Help with 66 monaco teardown [Re: poorboy] #2980704
11/01/21 08:07 PM
11/01/21 08:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is there not a removable piece in the center of the trans crossmember held in with four bolts? Looks like this.
Re: Help with 66 monaco teardown [Re: stumpy] #2980709
11/01/21 08:29 PM
11/01/21 08:29 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
No thats what i expected. Somebody monkeyed with it. I dont know why. I removed most of the bolts, will finish tomorrow. Bizarre. Thx
Re: Help with 66 monaco teardown [Re: mro] #2980795
11/02/21 08:32 AM
11/02/21 08:32 AM
IMGTX Offline
IMGTX  Offline
On the cars I have worked on with a fixed rear cross member you can unbolt the rear mount and slide the transmission out of the crossmember by lifting the engine up to clear the oil pan, then move it out the front of the car.
I am used to seeing removable center cross members on mopars. Weird. shruggy
Re: Help with 66 monaco teardown [Re: IMGTX] #2981028
11/02/21 07:15 PM
11/02/21 07:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Some of the early C bodies had 6 bolts holding the trans crossmember in, two bolts are up inside of the channel.
I do also remember lifting the motor sliding a few forward to clear the trans crossmember like mentioned earlier, but I thought those were the mid 70s version with a separate torsion bar crossmember and trans crossmembers. The trans cross members were removable, but you still had to slide the trans forward to clear the torsion bar crossmember.
