Oriflow oem front shocks #2980196
10/31/21 11:42 AM
10/31/21 11:42 AM
Maryland
glenngomango Offline OP
Maryland
I was planning on installing a set of nos shocks but the outside sleeve has separated from the top post. I see no signs of damage. Can the shock be repaired or used?
Re: Oriflow oem front shocks [Re: glenngomango] #2980199
10/31/21 11:44 AM
10/31/21 11:44 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I guess you could install it to make sure it was really good, if so then reattach the sleeve.
Re: Oriflow oem front shocks [Re: 340Cuda] #2980338
10/31/21 07:04 PM
10/31/21 07:04 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Hi Glenn , isn't that dust tube just tack or spot welded in 3 or 4 spots on the top ? Do you have a Mopar Buddy with a Tig welder ? A Mig will also do it , but might burn the paint up top a little more . drive Worth a try . shruggy I know I would try to save them . Ronnie
Re: Oriflow oem front shocks [Re: 1969ronnie] #2980903
11/02/21 01:18 PM
11/02/21 01:18 PM
Maryland
Maryland
Ronnie, it appears the top sleeve was pressed onto the stud base. I see no signs of a weld but that may do the trick. Thanks
Re: Oriflow oem front shocks [Re: glenngomango] #2980965
11/02/21 04:10 PM
11/02/21 04:10 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
If it was just pressed on then I would crimp it a little and/or then either JB weld or silver solder it in place......
