Fuel line leak fix #297990
04/24/09 01:01 AM
04/24/09 01:01 AM
Texas
6packattk Offline OP
Texas
I have a 91 dakota and the fuel return line has a pin hole leak in fuel line out of pump in tank and it is plastic,not thrilled with plastic but since it has a factory connector to steel line on frame and to pump,and dealer said no longer a stocking item.I need to repair,any suggestions.I have not dropped tank to get a good look at how it is tied in to steel line on frame but by feel I think it is 1 piece.Started smelling fuel with window down at a drive thru,sure enough spraying fuel out a pinhole in line.Any help would be appreciated,thanks
Re: Fuel line leak fix [Re: 6packattk] #297991
04/24/09 01:10 AM
04/24/09 01:10 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had a similar problem on a GM with plastic fuel lines (LT1 actually.)
What I did..was to cut the line were the leak was, and found a double barbed brass fitting that was a very tight fit in the line (didn't want to slide in by hand) and heated the fitting up, then jammed it into the plastic line. Did that for each side of the fitting, put a couple of small hose clamps on it and that was it.
That fix was a few years ago (and did it in Oz actually) and it is still going strong with no leaks.
Re: Fuel line leak fix [Re: OzHemi] #297992
04/24/09 01:17 AM
04/24/09 01:17 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Did you use a blow torch to heat it up??
Most parts houses will carry parts to repair the plastic fuel lines... Like Jeff said the brass barded style works pretty well...
Re: Fuel line leak fix [Re: 1_WILD_RT] #297993
04/24/09 01:21 AM
04/24/09 01:21 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Actually...
It was "winter" in Oz, and we had a fire going in the fire box at the shop (like a big steel cylinder with a door)...I set the brass fitting on it till it was hot, then picked it up with some gloves and jammed it in the plastic line quickly.
(It was a kinda cold and rainy day...that fire box thing would warm the shop up in no time...I am a wimp when it comes to under 60 degree temps. )
Re: Fuel line leak fix [Re: OzHemi] #297994
04/24/09 01:22 AM
04/24/09 01:22 AM
Texas
Texas
Thanks,I was thinking would get quarter inch nipple and cut line(the part I am not wanting to do)and take 3/8 fuel hose over it and clamp hose on each end over where the nipple is installed inside to like double the coverage.I tried splitting a hose and clamping over it without cutting line cause the factory connector to pump is larger than half inch diameter so can`t slide hose down line in 1 piece,it leaked of course.Was kind of shocked when they say can`t buy one and I have not used plastic for fuel ever.So definately want ideas before i cut it.Sure don`t want to find my fix leaks.
Re: Fuel line leak fix [Re: 1_WILD_RT] #297995
04/24/09 01:23 AM
04/24/09 01:23 AM
Texas
Texas
Re: Fuel line leak fix [Re: 1_WILD_RT] #297996
04/24/09 01:35 AM
04/24/09 01:35 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Good idea if places here have repair kits for it
Being in Melbourne...(and thier cars do not use plastic lines at all..) I had to improvise
The fix worked great though, so at least it's a way to go for you... the rubber hose over the top idea sounds abit 'maybe-not' to me
Re: Fuel line leak fix [Re: OzHemi] #297997
04/24/09 01:57 AM
04/24/09 01:57 AM
Texas
Texas
I will use your route,was not thinking plastic would handle hose clamping well but will try to see if the local parts houses have a brass double barbed type fitting and a couple hose clamps and will keep fingers crossed.Just not liking plastic anything with fuel but guess that is the way of the world.Changed the pump years ago and must of forgot it was lined in plastic.I would think they could scrimp elsewhere but fuel line.91 tells me they have done it for years though.Thanks for your input guys.....
Re: Fuel line leak fix [Re: 6packattk] #297998
04/24/09 02:02 AM
04/24/09 02:02 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Yep..plastic is common now a days. My daily driver (LS1 powered Camaro) has a plastic intake, and plastic fuel lines from the fuel rail to the hard lines on the frame.
Re: Fuel line leak fix [Re: OzHemi] #297999
04/24/09 10:50 AM
04/24/09 10:50 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The barbs are even a factory fix.I just heat water till its boiling and shove the line in it.It expands and put in the barb.Its a return so there isnt much pressure on it anyway.Rocky
Chrysler Firepower
Re: Fuel line leak fix [Re: therocks] #298000
04/24/09 04:00 PM
04/24/09 04:00 PM
Texas
Texas
Its a wrap,just went and bought a brass fitting and new hose clamps and I can smoke on drivers side of truck again without explosions.Thanks for the help fellas.....
Re: Fuel line leak fix [Re: 6packattk] #298001
04/24/09 04:15 PM
04/24/09 04:15 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Sweet
