HELP! I need an unmolested Indy 400-3 intake #2966022
09/21/21 01:32 PM
09/21/21 01:32 PM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey, I need a 400-3 intake for my 498" Brodix headed Bonneville bullet. If you have one or know of one, please let me know. Undy does not have any available at this time. Thanks
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Lifsgrt] #2966029
09/21/21 01:47 PM
09/21/21 01:47 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Thought I had one but it is a tall deck. Good luck with your search.
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Jeremiah] #2966054
09/21/21 02:46 PM
09/21/21 02:46 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks for looking!
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Lifsgrt] #2966058
09/21/21 02:54 PM
09/21/21 02:54 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have one that is fully molested and setup for a 4500 carb...I might consider selling.
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Lifsgrt] #2966063
09/21/21 02:57 PM
09/21/21 02:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Indy manifold on B1 heads?
Re: HELP! I need an unmolested Indy 400-3 intake [Re: fast68plymouth] #2966079
09/21/21 04:05 PM
09/21/21 04:05 PM
Pa
Hot 340 Online content
Hot 340  Online Content
Pa
prob budget sportsmans
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Hot 340] #2967720
09/27/21 08:45 AM
09/27/21 08:45 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'd bet he means the 3X Indy. Those B1 intakes are pretty good though. I'm wondering if you have a scoop/turbulance issue. Like someone mentioned simple AND CHEAPER AND EASIER TO PACKAGE. Individual EGT's are adequate to determine distribution. This is the way we used to in NASCAR and they ran WOT for more than 9 seconds too.
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Hot 340] #2979945
10/30/21 04:01 PM
10/30/21 04:01 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Actually, non-budget fully ported B1MC heads with 2.4" Ti intake valves. Ports actually too large for this application. Need a smaller port manifold that can be ported for good flow then installed with the mis-match at the head.
Re: HELP! I need an unmolested Indy 400-3 intake [Re: HardcoreB] #2979948
10/30/21 04:06 PM
10/30/21 04:06 PM
Lifsgrt Offline OP
Lifsgrt  Offline OP
HardcoreB, this B1 instake flows well for what it was designed and ported to do, but it was not ported for land speed racing, heavy load at speed. Car (1969 Daytona clone) ran almoat 231mph as is, but I agree turbulence at the carb had a lot to do with the problems of distro. Moroso DS-2s that grew 2 1/2" in diameter at that speed caused the final drive ratio to be way too high, compounding the problem.
Still need an uncut Indy 400-3.
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Lifsgrt] #2980060
10/30/21 09:39 PM
10/30/21 09:39 PM
Are the DS2 tires allowed to run above 175.+MPH by SCTA and BNI now?
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Cab_Burge] #2980068
10/30/21 09:58 PM
10/30/21 09:58 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Hughes Engines sells that low deck INDY 400-3 (4500) intake and they’re in stock.
https://www.hughesengines.com/Index...w==&level2=SW5keQ==&partid=23648
EDIT: Their checkout leads a person to believe they're in stock. LOL
"Any fool can know. The point is to understand"
- A. Einstein
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Lifsgrt] #2980812
11/02/21 09:17 AM
11/02/21 09:17 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I don't know how your application is any different than a NASCAR engine? Other than a restrictor motor, any intake i have even seen has been ported in a conventional way with no reduction in cross-section.
Re: HELP! I need an unmolested Indy 400-3 intake [Re: EvilB1Dart] #2980821
11/02/21 09:44 AM
11/02/21 09:44 AM
Sticky South
Rodenteliminator Offline
Sticky South
Just talked to Hughes, none in stock and no ETA on any coming in, I am looking for one also.
Sorry honey I spent the rent
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Rodenteliminator] #2980847
11/02/21 11:17 AM
11/02/21 11:17 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I just thought of it but did any of you guys contact Moparts member Jack Moore
He always has stuff laying around.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Cab_Burge] #2982266
11/06/21 01:18 AM
11/06/21 01:18 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Yes, no problem.
Re: HELP! I need an unmolested Indy 400-3 intake [Re: pittsburghracer] #2982267
11/06/21 01:22 AM
11/06/21 01:22 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Hey, can't find a Jack Moore on here. If you can get me in touch with him I will appreciate it. Just spoke with Indy yesterday. They said the manifolds should be poured today and available in 4-6 weeks. But that is the same story they told me just over two months ago. Hopefully they will be available soon.
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Lifsgrt] #2982271
11/06/21 02:51 AM
11/06/21 02:51 AM
try Moore and Moore racing.
He usually start postings his end of the year adds on here about now luck
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Cab_Burge] #2982274
11/06/21 06:06 AM
11/06/21 06:06 AM
PA.
"Little"John
"Little"John
PA.
He has been listing some stuff on Facebook.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: HELP! I need an unmolested Indy 400-3 intake [Re: Lifsgrt] #2982310
11/06/21 10:13 AM
11/06/21 10:13 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If I see Jack in canton this weekend I will get his number for you up
Gus beer
64 Plymouth Savoy
Dana 60
Re: HELP! I need an unmolested Indy 400-3 intake [Re: fourgearsavoy] #2982343
11/06/21 11:57 AM
11/06/21 11:57 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I talked to Jack last weekend and mentioned someone here was looking for a manifold , he said he'll check it not sure he got around to it judging by the previous posts
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
