727 rebuild - shelf life? #297977
04/24/09 12:33 AM
04/24/09 12:33 AM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
I have a chance to pick up a 727 from a 70RR that was rebuilt about 2yrs ago to stock specs, but never installed. I know the seller and he showed me the receipts, so I don't doubt the condition. The pan was loose so I could look inside and see it was clean/dry.
What is the "shelf life" for a 727 rebuild, that is, sitting dry, how long before it should be rechecked?
Re: 727 rebuild - shelf life? [Re: 70runner] #297978
04/24/09 12:56 AM
04/24/09 12:56 AM
minnesota, USA
greenfire Offline
greenfire  Offline
minnesota, USA
if the rebuild was done right, and the unit stored properly, not laying out behind a garage somewhere it should be good for a long time. personally if i got it, i would install it then fill with proper fluid and allow it to rest or seep in to all the internal areas for a day or so, then drive it. just my worth
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: 727 rebuild - shelf life? [Re: greenfire] #297979
04/24/09 06:31 AM
04/24/09 06:31 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Get it and go - no sweat if it was stored in doors.
Re: 727 rebuild - shelf life? [Re: MoparforLife] #297980
04/24/09 12:54 PM
04/24/09 12:54 PM
70runner Offline OP
70runner  Offline OP
Yes, it was stored indoors. He even wrapped it with plastic and sealed it.
Re: 727 rebuild - shelf life? [Re: 70runner] #297981
04/24/09 01:05 PM
04/24/09 01:05 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I recenty sold one that I did back in 2000 !
So your two-year-deal should not be a problem.
Re: 727 rebuild - shelf life? [Re: dOoC] #297982
04/24/09 10:39 PM
04/24/09 10:39 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I agree with all the above...If the trans was never run the seals will stay fresh for a very long time if stored indoors...After a trans is run and is heat cycled you run a greater risk of dried out/brittle seals during storage....
