Brake Master Cylinder Deburring Tool #2977614
10/23/21 03:31 PM
10/23/21 03:31 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Okay, here's one in the minutia column. When I was young many, many moons ago there was a tool to deburr the compensating port in a brake master cylinder from the interior of the bore after you had honed the bore. Purpose was to eliminate the sharp lip at the compensating port after honing to prevent the cups from being cut on the edge of the port. Now I can't find anything like it. Can't even find it being necessary to deburr Anyone shed any light on this?
Re: Brake Master Cylinder Deburring Tool [Re: 6PakBee] #2977640
10/23/21 04:52 PM
10/23/21 04:52 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
How about a right angle dental pick? You're just looking to knock the sharp edges off.
Ever seen a oil pan bolt wrench for a model T? They exist but are pretty pointless.
Angry white pureblood male
Re: Brake Master Cylinder Deburring Tool [Re: ruderunner] #2977683
10/23/21 06:39 PM
10/23/21 06:39 PM
North Dakota
6PakBee Offline OP
6PakBee  Offline OP
North Dakota
Might work. The last time I THINK I saw one was when I was about 18. IIRC was a rod with a 90 degree bend at the end and a conical fluted end. But that was a lot of years ago and I don't know if my last two functioning brain cells are accurately remembering what it looked like.
Re: Brake Master Cylinder Deburring Tool [Re: 6PakBee] #2977829
10/24/21 10:58 AM
10/24/21 10:58 AM
Alberta
rustbuckett68 Offline
Alberta
Riffle file?
Re: Brake Master Cylinder Deburring Tool [Re: rustbuckett68] #2977888
10/24/21 02:40 PM
10/24/21 02:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use deburring tools at work and at home rebuilding transmissions. I have found them online in many shapes and sizes just Google it and there are hundreds of different shapes and sizes.
Gus beer
64 Plymouth Savoy
Dana 60
