Bracket Racing Ramblings
#2976842
10/21/21 02:05 PM
10/21/21 02:05 PM
Posts: 2,475 SW Ohio
cgall
SW Ohio
This season I went back to my old footbrake Duster, ran Pro Bracket at local track. Last year I retired and set a budget for racing, 12 races at local track, no travel, and new set of slicks. I only made it past the third round once all year, there are a lot of sharks racing at this track. Made 59 runs, had no breakage. Had a lot of fun just keeping it real simple, will do the same next year.
Won 19 rounds Lost 17 rounds
Best ET 1/8th mile 6.503 Best ET 1/4 mile 10.310
Car is '72 Duster, ladder bar, 4.86 gear, 29 X 12.5 tire, pump gas 440 with Eddie heads, 727 manually shifted, weighs 2950 with driver.
Re: Bracket Racing Ramblings
[Re: HardcoreB]
#2976851
10/21/21 02:32 PM
10/21/21 02:32 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Thing has got to be singing in the 1/4 with that steep gear
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 69dart]
#2976859
10/21/21 02:50 PM
10/21/21 02:50 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I am leaving my muffs on this weekend and trying the street class. It would be nice to at least win a few rounds. My best et is exactly what yours is in the 1/8 . 3600 lb F Body small block with a ton of stroke. LOL
6.50 @105.26
[Re: Kindafast]
#2976889
10/21/21 04:40 PM
10/21/21 04:40 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
well you were out and racing . thats always good .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 69dart]
#2976921
10/21/21 06:38 PM
10/21/21 06:38 PM
Posts: 1,030 ohio
67mprfan
ohio
Its brutal these days. I struggled this year. The thousandths just never seemed to fall my way. I'm thinking I might try something new next year. You are 1 that I usually expect to go a lot farther than me. Lol Keep up the good work
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
