A500 Trans. overdrive problem #297655
04/23/09 06:06 PM
04/23/09 06:06 PM
Ridgeland, WI, 54763
Curt57 Offline OP
Curt57  Offline OP
I have the overdrive on my A500 in my Dakota hooked up to a switch. It was working fine til I was driving 55-60 in overdrive and it was like some one through an anchor out. I switched out of o.d. and it worked fine in 1,2, and drive. Put it back in o.d. and it binds up again. What happened?
THANKS, Curt
Re: A500 Trans. overdrive problem [Re: Curt57] #297656
04/23/09 07:13 PM
04/23/09 07:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Sounds like your OD planataries are bugered up. You can remove the OD section with out removeing the rest of the trans and fix it.
