How to reset a brake proportioning valve?
#2975720
10/18/21 03:38 PM
10/18/21 03:38 PM
Posts: 5,797 minnarusta
TX9H6E4CUDA
minnarusta
Good afternoon everyone So on my 1970 Cuda (front disc/rear drum) I was bleeding the brakes and I think I tripped the proportioning valve (found a front bleeder screw not tight while doing the rear). While I was bleeding the brakes, I heard a click noise. I am now only getting fluid the passenger front caliper. Every other wheel is dry. Every single piece of the braking system is brand including the valve. Any suggestions on how to reset this?
Any help is greatly appreciated
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: How to reset a brake proportioning valve?
[Re: TX9H6E4CUDA]
#2975729
10/18/21 03:55 PM
10/18/21 03:55 PM
Posts: 9,560 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
The little rubber covered protrusion on the purporting valve usually does it. If the rubber is gone it looks like the end of like a 16 penny nail and sticks out maybe 1/4 inch.
Look for something like this weather its a cast or machined unit. This is a bit newer unit but same process, Id think.
STOP POTATO HATE!
[Re: TX9H6E4CUDA]
#2975732
10/18/21 03:57 PM
10/18/21 03:57 PM
Posts: 6,319 nowhere
Sniper
nowhere
Generally, they cut off the front or the rear, but everything but one of the four. The FSM has the reset procedure if there is one. Here's a link to an electronic copy. https://mymopar.com/service-manuals/
[Re: Mr PotatoHead]
#2975745
10/18/21 04:23 PM
10/18/21 04:23 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The little rubber covered protrusion on the purporting valve usually does it. The circled part is the metering valve. What you probably heard click is the piston that triggers the warning light. The book says it should re-center itself when pressure is applied to the working system but, if not, the switch has to be removed and the piston re-centered manually.
[Re: John_Kunkel]
#2975766
10/18/21 05:17 PM
10/18/21 05:17 PM
Posts: 2,386 White Plains, NY
VCODE
White Plains, NY
Sometimes just step on the brake pedal hard and fast.
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#2975777
10/18/21 05:40 PM
10/18/21 05:40 PM
TX9H6E4CUDA
minnarusta
So thank you everyone for the help.....I'm an idiot. I accidentally swapped two lines so both Master cylinder reservoirs were going into the front wheels block. That's why I only had the front right getting fluid. I swapped the lines and got it to bleed.
Now I am going to grab a beer and reflect.
Thank you everyone for the help
