572 Hemi #2975674
10/18/21 02:04 PM
10/18/21 02:04 PM
South Carolina
carhunter Offline OP
South Carolina
I'm just wondering what spark plugs there running in their Hemi.I was running Ac Delco R43X65 but can't find them anymore. Thanks for any help.
Re: 572 Hemi [Re: carhunter] #2975701
10/18/21 03:12 PM
10/18/21 03:12 PM
What compression ratio, what fuel are you using and is this a street only or street and strip or race car only?
Hemi motors are all a little different, depending on the builder and application shruggy whistling work
BTW, I use to build, race and drive gen 1 and gen 2 hemi on the street and drag raced them also, I'm considering building a using Gen 3 now on a street project luck
My message is all three are different motors and do not like the same parts or tunes shruggy
Re: 572 Hemi [Re: carhunter] #2975704
10/18/21 03:16 PM
10/18/21 03:16 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Never heard of that number, and I was a sales rep for a Delco Remy warehouse for more years than I care to admit.
Re: 572 Hemi [Re: Cab_Burge] #2975714
10/18/21 03:27 PM
10/18/21 03:27 PM
South Carolina
South Carolina
Iron block 10.5 -1 comp. 2x4 street car, alum. heads, pump gas.
Re: 572 Hemi [Re: John Brown] #2975718
10/18/21 03:35 PM
10/18/21 03:35 PM
South Carolina
South Carolina
I doubled checked the plugs I pulled out and your right.I went by the sheet the builder gave me and it's not real neat writing, I thought it was r43x65 but it's r43xls thanks.
Re: 572 Hemi [Re: carhunter] #2975786
10/18/21 05:56 PM
10/18/21 05:56 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
it's been over 10 years since me and my friends ran 2nd gen hemi's.
we used to run NGK V grove plugs in our hemi's. if i remember correctly they were gr4 or 5.
perception is 90% of reality
Re: 572 Hemi [Re: Mr T2U] #2975790
10/18/21 06:07 PM
10/18/21 06:07 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I run NGK GR5 plugs in my 528 Hemi.
Re: 572 Hemi [Re: Paul_B] #2975980
10/19/21 08:10 AM
10/19/21 08:10 AM
an8sec70cuda Offline
NGK 4554 (R5671A-8). 575" all aluminum pump gas motor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 572 Hemi [Re: an8sec70cuda] #2976053
10/19/21 11:28 AM
10/19/21 11:28 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have also run both NGK R5671A-8's and GR5's, along with with Champion RN12YC and 10YC's. Seems to not matter. It runs and like all of them just fine on pump gas.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 572 Hemi [Re: 6PKRTSE] #2976076
10/19/21 12:20 PM
10/19/21 12:20 PM
South Carolina
South Carolina
Thanks all for the info.
Re: 572 Hemi [Re: carhunter] #2976132
10/19/21 02:56 PM
10/19/21 02:56 PM
I would use either a Autolite #3923 or 3924. Champion # RC9YC or RN9YC, The C series plugs use a 5/8 inch spark plug body and the N series use the original 13/16 socket size and body. The R stands for resistor type plug, which is what you want to use on a street motor up
Both of those Autolite plugs are resistor type also, the 3924 is a little hotter heat range than the 3923 is scopeup
It is always safer to use a colder plug when tuning a new motor than to hot of one, I would try the #3923 first and go from their wrench twocents
The colder plug will get blacker quicker andtry to foul out than the hotter plug will so try the new colder set first gapped at .035 or wider up to .050 and see if they are running clean or getting to brown or black from being to cold.
Then go ahead and try the hotter plug next and look at them and decide after that which one you want to run in the motor full time twocents scope up
