Block purchase #2974572
10/15/21 09:38 AM
10/15/21 09:38 AM
texas
thewolf1970 Offline OP
texas
Looking at buying a new block. Has anyone used the callies bbm block yet? Have looked at the bulldog as well but seems his lead times are not that great. Debating on going with a hemi or keep using the wedge style b1 platform. Aluminum is great but like a KB or Indy just to much right now. Used ones are hard to find to. Thanks! Sean
Re: Block purchase [Re: thewolf1970] #2974645
10/15/21 01:41 PM
10/15/21 01:41 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
If you get a bulldog block, be prepared to finish the block at the machine shop. My new bulldog block is back at the machine shop (3rd time) now for the mains being .005 too tight and egg shaped.
At this point, i would rather have my sister work at the bunny ranch then buy another bulldog block
Joe
Without Data, you’re just another guy with an opinion.
Re: Block purchase [Re: sr4440] #2974646
10/15/21 01:43 PM
10/15/21 01:43 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Not to kick sand in your face, but I have a Bulldog here that when we pressure tested it, leaked water out of the oil pump bolt holes. Better to know before it happens......Todd
Re: Block purchase [Re: sasquatch] #2974648
10/15/21 01:58 PM
10/15/21 01:58 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Great, but so far none of the holes have been tapped to the proper depth. frown
Joe
Re: Block purchase [Re: sr4440] #2974665
10/15/21 02:34 PM
10/15/21 02:34 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Talked with the old man Ray Barton the other day...We had a nice long discussion by phone. Blocks came up, and he really likes the new Callies iron blocks. No issues to date, and he has built 40 of them this year so far. I almost bought a Bulldog low deck last year or so....Glad I did not.
Re: Block purchase [Re: sasquatch] #2974666
10/15/21 02:41 PM
10/15/21 02:41 PM
AndyF Offline
AndyF  Offline
Not a surprise given the history of Bulldog blocks.
Re: Block purchase [Re: Dragula] #2974667
10/15/21 02:43 PM
10/15/21 02:43 PM
AndyF Offline
AndyF  Offline
Callies might be okay once they figure out how to do all the machine work. Some pictures floating around of partially machined blocks.
Re: Block purchase [Re: thewolf1970] #2974669
10/15/21 02:45 PM
10/15/21 02:45 PM
AndyF Offline
AndyF  Offline
Best bet is to talk to pros who build engines for a living. They see enough stuff that they know what is right and what is wrong. Chuck at Best Machine is probably the best guy to ask about blocks. He'll tell what is available and if it will work or not. Sad to say, a lot of the stuff on the market is junk so you have to be super careful before you pull the trigger.
Re: Block purchase [Re: AndyF] #2974699
10/15/21 04:41 PM
10/15/21 04:41 PM
texas
texas
Looks like I will wait a bit and go with an KB block. Just do not need the headaches lol.
Re: Block purchase [Re: thewolf1970] #2974705
10/15/21 05:19 PM
10/15/21 05:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It might be an exceptionally long bit....good luck.
Rich H.
Esse Quam Videri
Re: Block purchase [Re: AndyF] #2974716
10/15/21 06:04 PM
10/15/21 06:04 PM
Dragula Offline
Dragula  Offline
No issues per Ray Barton, and as I said, he built 40 this year alone with those blocks. Its using the old Mopar tooling and castings...So as long as the corect controls are in place, life should be good.
Re: Block purchase [Re: thewolf1970] #2975319
10/17/21 01:15 PM
10/17/21 01:15 PM
Finland
Lancer273cid Offline
Finland
Have you thought about Bill Mitchell Products aluminum blocks? Anyone here having experience with that block??
Re: Block purchase [Re: Lancer273cid] #2975346
10/17/21 03:06 PM
10/17/21 03:06 PM
Texas
Chief Offline
Chief  Offline
Texas
I too am looking for a block. I want to build another low deck, but would consider a tall deck.
I currently have an Indy Maxx and when I ordered it I had them do all the machine work. It turned out flawless. So I'm considering them again if I don't find a used one.
Dave Covey
Re: Block purchase [Re: Lancer273cid] #2975962
10/19/21 04:17 AM
10/19/21 04:17 AM
gregsdart Offline
gregsdart  Offline
Myself and 440jim have BMP Aluminum blocks. I spent about $1,000 to prep the block. It took a lot of honing to get to 4.500. Line hone to touch up one main. I need to relieve the block a bit on #8, so there is more room for the roller lifter tie bar. So far I am happy with what I see. I have been held up on this project by health issues. I can get back to it soon if all goes well.
Re: Block purchase [Re: thewolf1970] #2976005
10/19/21 09:38 AM
10/19/21 09:38 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
How old are you now?
2011 Drag Pak Challenger
Re: Block purchase [Re: gregsdart] #2976048
10/19/21 11:16 AM
10/19/21 11:16 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Keep at it, I hope you can get past the health issues !!!!!!
Re: Block purchase [Re: Lancer273cid] #2976095
10/19/21 01:12 PM
10/19/21 01:12 PM
NC
440Jim Offline
440Jim  Offline
NC
I am building a new engine with the BMP aluminum block right now.
See my series of posts, 572 B1 org Part 1, Part 2, Part 3, etc.
Link to Part 1 - Buying Parts
The machine shop I used bored it from 4.490 to close to final size before honing it the final amount.
I am very happy with it so far. Trying to find time to do assembly now.
Re: Block purchase [Re: rickseeman] #2976106
10/19/21 01:45 PM
10/19/21 01:45 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Was going to ask the other day if they were still having issues.
I guess I don't need to now.
'63 Dodge 330
11.19 @ 121 mph
Re: Block purchase [Re: rickseeman] #2976153
10/19/21 04:45 PM
10/19/21 04:45 PM
texas
texas
Ancient..............
Re: Block purchase [Re: thewolf1970] #2976389
10/20/21 07:54 AM
10/20/21 07:54 AM
an8sec70cuda Offline
I would explore other options before deciding on a KB block. A Callies block bought through a builder seems like a good option right now. Have them check it out and correct any issues before you get ahold to it.
CHIP
'06 GMC 2500HD LBZ Duramax
