68 Ply Fury blower motor not working #2974638
10/15/21 01:11 PM
10/15/21 01:11 PM
Indianapolis In. usa
Quickrunner Offline OP
My son's 68 fury has no action on the blower motor on any switch position and the fuse is good. Any quick thoughts on this, is there a hidden relay or anything simple to check short of taking the dash apart? Thanks
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: 68 Ply Fury blower motor not working [Re: Quickrunner] #2974644
10/15/21 01:39 PM
10/15/21 01:39 PM
Jumped a wire from motor to bat and motor blows, must be something in the dash
Re: 68 Ply Fury blower motor not working [Re: Quickrunner] #2974651
10/15/21 02:04 PM
10/15/21 02:04 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Some basic areas to look....................
Check for voltage at the fuse.
Nothing on either side=problem is ahead of the fuse box.
Voltage on both sides=problem is after the fuse box. follow the wiring and eventually you'll find the problem.
Check for voltage at resistor block, check resistor block for open circuit. They do melt and fail.
Because the old cars usually didn't have any relays, all the power goes through the switch.....
check the switch by removing it and inspecting, they often melt internally.
Rich H.
Esse Quam Videri
Re: 68 Ply Fury blower motor not working [Re: ZIPPY] #2974660
10/15/21 02:26 PM
10/15/21 02:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
IIRC, on high speed the blower resistor is bypassed?
