Funny review of 24ft power washer extension for gutters #2973094
10/11/21 05:56 PM
10/11/21 05:56 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Buying something to clean the gutter guards on the 2nd story of our new house (house is 20 years old but new to us). Lots of leaves. UGH. I spoke with the 2 older neighbors to see if they might consider getting rid of their huge trees that are over my house. I even said I'd pay. They said no but I could have them trimmed. After I get done they are gonna wish they had agreed to take them down cause they are gonna be FLAT to the property line. Gonna look stupid and probably unstable.
Anyway, I'm NOT getting up on the roof or up a 25ft ladder so I found a "professional grade" telescoping pole for a pressure washer. The hose runs up inside the telescoping pole. It has a 180 degree steel tubing bend at the top for a pressure washer tip to clean gutters. Should have it by Friday.
Mostly very good reviews although at full extension it sounds like a HANDFUL. People claimed they were "sore for days" and basically used the exiting pressure to "steer" the pole.
One review said, "do not use while on a ladder unless you have previous circus experience". I busted out laughing.
Re: Funny review of 24ft power washer extension for gutters [Re: 71TA] #2973152
10/11/21 08:51 PM
10/11/21 08:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Sounds interesting do you have a link ? Does it require a pressure washer or a regular hose ? beer
Re: Funny review of 24ft power washer extension for gutters [Re: TJP] #2973413
10/12/21 12:50 PM
10/12/21 12:50 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Meant for s pressure washer. Ill be using like a 1600psi electric one. I dont want to blow the fascia boards off smile
https://www.northerntool.com/shop/tools/product_200680695_200680695
The 180 degree bend for gutters is sold separately there too.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Funny review of 24ft power washer extension for gutters [Re: 71TA] #2973711
10/12/21 09:32 PM
10/12/21 09:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks for the info, Seems a bit pricey and that high of high pressure to clean gutters is a bit concerning as well?? I could see where some shingle damage could easily occur whistling
And the
Quote
Free Back Belt With purchase of 6-24ft. professional-grade telescoping pressure washer wand.
$29.99 Value
See Details
whistling beer
Re: Funny review of 24ft power washer extension for gutters [Re: TJP] #2973741
10/12/21 10:18 PM
10/12/21 10:18 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I'd be kinda worried about it blowing too much water up under the shingles and maybe rotting the roof decking, but of course.....letting the gutters get clogged up can do the same thing.
Re: Funny review of 24ft power washer extension for gutters [Re: JDMopar] #2973890
10/13/21 12:01 PM
10/13/21 12:01 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
It's rated for 4000psi but like I said I'm just using a 1600psi electric home depot washer.
Looks like it comes with a garden hose connection too if worried about the pressure.
One company that sells a pro gutter vacuum has a $300 optional GoPro wireless and a mount for your I phone. I may get that too.
Re: Funny review of 24ft power washer extension for gutters [Re: 71TA] #2974088
10/13/21 07:45 PM
10/13/21 07:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A 24' extension with a 180 degree turn would give that turned end a lot of leverage against the person holding the pressure end.
I sure hope the gutters are still attached to the roof/soffit really well, could have the gutters falling down towards you pretty quickly, especially if they are already full of years of built up, well set, stuff and you add another 1600 psi of force against the nails that hold the gutters in place.
Have you given any thought about where all the stuff that was in the gutter is going to go after it leaves the gutter?
Holding onto the 1600 psi wand with a 24' extension, blowing water against a floppy loose gutter while dodging the flying gutter debris, could also become a big game of dodge the falling gutter and its leaf content. Be sure to catch the event on video, it could be worth some money, or at least a good laugh after you recover from treatment. We wouldn't laugh at such a video if it became available... we promise..... whistling Gene
Re: Funny review of 24ft power washer extension for gutters [Re: poorboy] #2974095
10/13/21 07:56 PM
10/13/21 07:56 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I made a fixture to attach around 25 foot of gutter with a turndown at the end To my gas powered leaf blower. Go out when the leaves are good a dry and blow the gutters clean, do it a couple of times/year and it works great. Odd looking I'll admit but quick and efficient.
Re: Funny review of 24ft power washer extension for gutters [Re: poorboy] #2974127
10/13/21 09:02 PM
10/13/21 09:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
laugh2 up popcorn
Re: Funny review of 24ft power washer extension for gutters [Re: 71TA] #2974378
10/14/21 05:03 PM
10/14/21 05:03 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Pin Oak Leaves are the worst I have seen for blocking gutters.
The way they traditionally attach down spouts to gutters is bad practice.
It causes blockages.
At the end of a gutter run,
a long radius ninety degree elbow should smoothly turn the whole gutter width downward,
that would not block up with leaves, twigs, etc.
In mineral processing plants where both rocks and water are flowing in pipes and chutes,
you learn the hard way not to create a gutter-like downspout connection,
it will jam frequently and wear out fast.
Someone should market a blockage resistant end of gutter turn down,
not the leaf filter gutter roofs,
or the “radius slot” tops that catch water but partially allow leaves to fall below the gutter where they eventually must be raked up.
Re: Funny review of 24ft power washer extension for gutters [Re: 71TA] #2974379
10/14/21 05:13 PM
10/14/21 05:13 PM
Addison Twp, Mi.
RobG Offline
RobG  Offline
Addison Twp, Mi.
I have two of these - one at the house and one up at the lake cottage. Get the shoulder harness if you are feeble. This thing is a beast to control when it is fully extended. you need to have a good standing position and learn to combat the forces as you lean into the pole. Plan on doing nothing the next day and have a good bottle of bourbon ready to wash down the Aleeve.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: Funny review of 24ft power washer extension for gutters [Re: TJP] #2974380
10/14/21 05:13 PM
10/14/21 05:13 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
1600psi is probably rated through the smallest orfice. And Im certain theres losses up the pole and especially at the 180 turn. I’ll be using the largest orfice with the 3/16” hole that fans out. Its not stronger than the spray at a car wash. And cause the pole says RATED for 4000psi, its not magic. It doesnt boost the pressure. I designed industrial hydraulic systems and robotic waterjet cutting systems for 30 years so I little first hand
knowledge. Give me a tiny bit of credit. Im not spending $$$ on equipment to blow the crud off the gutter guards on my new 2nd home lake house cause I are stoopid smile
So I thought the review was still funny.
Re: Funny review of 24ft power washer extension for gutters [Re: RobG] #2974383
10/14/21 05:17 PM
10/14/21 05:17 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
FEEBLE?!?! smile I have plenty of liquor at the lake house. Ill make a Harsens Island Ice Tea to ease the pain.
PS I ordered the wireless GOPro and Iphone mount so I can either watch watch Im doing or inspect after.
Re: Funny review of 24ft power washer extension for gutters [Re: 71TA] #2974396
10/14/21 06:22 PM
10/14/21 06:22 PM
East Bay, N. Cal.
calmopar Offline
calmopar  Offline
East Bay, N. Cal.
Please have another camera with a wide shot of you using the thing in case you capture something that could be YouTube gold.
Trying to enjoy life!
Re: Funny review of 24ft power washer extension for gutters [Re: calmopar] #2974577
10/15/21 09:57 AM
10/15/21 09:57 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Tried it last night. Worked BETTER THAN EXPECTED. Was a handful but I'm not a p&^^&y smile
No video. Too busy working 13 hours a day at my business then doing the handyman stuff at the lake house. I'd like to hire someone but .....trying to save a couple dollars so I can put a 35' Fountain on that boat lift
Did I mention that review was still funny. Even funnier now..
Re: Funny review of 24ft power washer extension for gutters [Re: 71TA] #2974604
10/15/21 11:04 AM
10/15/21 11:04 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
thanks for the report wink Does it throttle the pressure down at all or is it full bore ?
