Summit/Firecore distributor?
#2974302
10/14/21 12:37 PM
10/14/21 12:37 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Does this distributor look like a Summit/Firecore distributor? The only number on it is "A-1" on the bottom of the housing. It came on a complete low deck engine a friend bought, but didn't have a cap on it. Just need to know what it is so we can get a cap and use it...maybe. It does have the MSD style plug, but it's not an MSD piece. I think this is SUM-850082-1
Re: Summit/Firecore distributor?
[Re: an8sec70cuda]
#2974335
10/14/21 02:16 PM
10/14/21 02:16 PM
Posts: 277 MN
Willie68coronet
MN
Sure does look exactly like summit/ jegs/ firecore distributor. If it is, a stock replacement cap from a auto store will work. Or summit carries a male terminal (HEI style) cap and rotor kit that will work on that and a stock distributor
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Willie68coronet]
#2974885
10/16/21 09:30 AM
10/16/21 09:30 AM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Sure does look exactly like summit/ jegs/ firecore distributor. If it is, a stock replacement cap from a auto store will work. Or summit carries a male terminal (HEI style) cap and rotor kit that will work on that and a stock distributor It does take a factory style cap or you can get the HEI style cap for it. I would not recommend taking it apart like a Mopar distributor as that is where most people have problems with them. I have had one in my car going on 9 years now with zero issues and I was able to customize the curve without disassembly with picks and hemostats . I like the ease of adjustment and the HEI style cap is very secure with the Firecore wires. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2975981
10/19/21 08:14 AM
10/19/21 08:14 AM
an8sec70cuda
Given the reputation these things have, if we use it, I'll gut it and get a crank trigger.
