Re: What kind of crank is this?
[Re: IMGTX]
#2974023
10/13/21 04:47 PM
10/13/21 04:47 PM
Posts: 25,777 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Measure the bearing journals.
[Re: gzig5]
#2974031
10/13/21 05:16 PM
10/13/21 05:16 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I will measure the journals tomorrow. I know for a fact is isn't a 360 crank but didn't think to measure it. I always thought it was a forged 318 truck crank but never got around to looking too deep at it.
[Re: Cab_Burge]
#2974510
10/15/21 01:18 AM
10/15/21 01:18 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
273 and 318 used this forged crank as long as they came with a forged crank, 69 273 automatics were cast as were 69+ automatic 318s for a while then even manuals got cast cranks, I am not sure what year the manual 318 went cast. The only significant difference in this and 340 crank is the drilled journal, the 340 had a heavier rod and piston requiring some weight removed somewhere to balance it so a hole drilled in the journal it was. You could run a really light rod/piston to get close enough to balance it normally or better yet, drill the hole AND run light rods pistons AND balance it properly to make it real light and strong.
