low deck pistons availability #2973527
10/12/21 02:51 PM
10/12/21 02:51 PM
Raleigh, NC
Y
Youngblood Offline OP
Y
Raleigh, NC
I have a 400 getting stroked right now. Block was standard bore, but did not clean up at .030, so my brand new pistons will not work. 4.150 crank, 6.76 rods with .990 pins, looking for flat top or small dish in 040,050,055 now. Anyone carry this in forged shelf piston? Thanks for any direction
Re: low deck pistons availability [Re: Youngblood] #2973543
10/12/21 03:15 PM
10/12/21 03:15 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Can you go .033 over and be at 4.375?
Re: low deck pistons availability [Re: Youngblood] #2973547
10/12/21 03:27 PM
10/12/21 03:27 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Doesn't 440 Source keep .035/.040/.042 on the shelf?
Re: low deck pistons availability [Re: Youngblood] #2973559
10/12/21 03:59 PM
10/12/21 03:59 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
How many cylinders didn't clean? Sleeve it? Icon had all manner of pistons listed, but just checking their online catalog and they seem to have deleted a bunch. Might just be a technical error on their website, IDK. S/F....Ken M
Re: low deck pistons availability [Re: Youngblood] #2973604
10/12/21 04:53 PM
10/12/21 04:53 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
looks like you're setup is for the Mahle piston with 1.12 compression height. I don't think there are many pistons for that combo...
4.35 and 4.375 bore.
Re: low deck pistons availability [Re: krautrock] #2973633
10/12/21 06:08 PM
10/12/21 06:08 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Ross used to make a piston for that in 4.390 bore.
Re: low deck pistons availability [Re: fbs63] #2973645
10/12/21 07:04 PM
10/12/21 07:04 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
A friend had a set of Ross pistons for a the same or similar combo. Not sure if he still has them.
Alan Jones
Re: low deck pistons availability [Re: Youngblood] #2973682
10/12/21 08:27 PM
10/12/21 08:27 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Call Diamond and see what they have. They gave me a one dimensional change for free and it ended up being a modified shelf Chevy piston. Didn't cost anything.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: low deck pistons availability [Re: Youngblood] #2973862
10/13/21 11:04 AM
10/13/21 11:04 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I ran into same issue on my 400/470 build this year. My block was about .033 over after last hone. Couldn't find pistons easily. Ended up using a 2nd block which turned out to be cracked. Finally found a 3rd and that's so far so good but not out of the shop yet. Was supposed to be done and running in July. Just painful.
Re: low deck pistons availability [Re: Youngblood] #2974157
10/13/21 10:24 PM
10/13/21 10:24 PM
gregsdart Offline
gregsdart  Offline
[quote=Youngblood]I have a 400 getting stroked right now. Block was standard bore, but did not clean up at .030, so my brand new pistons will not work. 4.150 crank, 6.76 rods with .990 pins, looking for flat top or small dish in 040,050,055 now. Anyone carry this in forged shelf piston? Thanks for any direction [/quote
I had a Megablock 4.500 bore rehoned, scratches didn't disappear till 4.5043. I had my old CP pistons coated by Line2Line. Cost $300 but worked great. 550 inch with 440-1 heads made 926 hp using those coated pistons. They coat them within .0025 of actual bore size, then run the motor through a breakin procedure in several steps. I believe in L2L. Coatings. They say they can make up as much as .020 overbore if needed. Call them and discuss your situation.
Re: low deck pistons availability [Re: gregsdart] #2974204
10/14/21 07:00 AM
10/14/21 07:00 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I really wanted to do that but my shop was worried about it being consistent and not coming off being so thick. Good to hear. I may do that on my .033 over block at some point.
Re: low deck pistons availability [Re: 80fbody] #2974219
10/14/21 08:13 AM
10/14/21 08:13 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
popcorn
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: low deck pistons availability [Re: fbs63] #2974264
10/14/21 10:37 AM
10/14/21 10:37 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i only see the 1.12ch ross piston in a 4.375 bore in the catalog. I emailed them about some of the 383 pistons in the 1.307ch and to get smaller dish or a 4.29 bore would've made it a custom piston. about $1100.
The OP might be in the situation.
https://www.rosspistons.com/wp-content/uploads/2016/08/RossPistons-Catalog.pdf
Re: low deck pistons availability [Re: gregsdart] #2974271
10/14/21 11:05 AM
10/14/21 11:05 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
You had me hoping there at first till the last paragraph. Mine is 4.53 I can find quite a few used sets at 4.5. I’ve looked on most all sites and no one stocks .030 over for some reason.
